Question about Oreck XL2200 Bagged Upright Vacuum
HOW DO i CLEAN MAIN TUBE IN HANDLE CLOGED
NOT PICKING UP
  • 328 Answers
You'll have to unpick or slide up the rubber rings on the back of the handle at the bottom where the rear of the bag is. Unclip the bag so that it moves freely, slide up the rubber rings and you'll find a series of pop locks. Push these in to take out the main dust spine pipe - also remove the power cord at the top of the handle to release the handle. In the middle of the spine there is one screw that bonds the top handle part to the spine, unscrew this so that you can split the two parts up and check for clogs. Also check the main dust channel that leads to the bag - it is notorious for clogging because of its relatively small dust channel.
Posted on Feb 20, 2009
Cannot remove the lid of main housing
I have a model Bissell Proheat Platinum II Model 1699 that was not spraying. It probably is similar to yours.
As stated in other posts, the heater is located within the lower half of the handle where the POWER HEATER switches are. There are quite a few screws. It's easy to miss the one at the very top of the handle. First remove the accessory caddy and then remove one half of the upper handle. The other half of the upper handle lifts straight up allowing you to split the lower part of the handle into a "V". It pivots at the bottom around the wheels. It took me a while to figure out that I needed to LIFT that part of the handle straight up.
Once you split the lower half, you will see the heater (aluminum box). There are two ports on the heater where the two lines connect to the heater (in and out). Use pliers to loosen the spring clip where the tubing connects to the heater to remove each line. My lines were okay. One of the ports on my heater was plugged. I used a 1/16" drill bit and hand reamed out the crud. You don't need to use a drill -- use your hand - it's safer. After you have cleaned out the ports and your tubing (if needed), suggest you try it out after reconnecting the lines to the heater but before you put the handle back together. You may find that the lines or port needs more cleaning. Make sure you have water in both the water and cleaning solution vessels. As you know, no water will spray if EITHER one is dry. Turn it on and then press the little spring that's still in the handle. Hopefully you will get a water spray.
When you put the handle back together, be careful that you don't crimp the tubing. Tuck them back in the notches in the handle.
Hope this helps . Good luck.
Apr 02, 2014 | Bissell 1698 PowerSteamer ProHeat Upright...
Not sure if i've got the bag installed properly. won't pick up anything.
When you turn the motor on, the bag should inflate quickly and firmly. If the bag does not inflate, you probably have an obstruction in the handle tube. The tube can be disassembled to remove the plug.
Feb 21, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My Bissell 25A3 ProHeat wont spray water
I had two problems. No water was coming out of the main unit (it was working fine via the powerbrush) and the flow indicator wasn't spinning. Because I'm out of warranty, I did two things (after trying all the options that were posted).
1. Removed the top of the main unit. There are 4 screws on the top back lid. Once you remove those, lift the back up towards the front. The front is snapped under the bottom casing. It should come up with a little pressure, but don't force it. With the top lid removed, I had to clean several of the rubber hosing by removing them and running under warm water. I actually used a long wooden skewer to scrape the grime in the tube. Make sure you do one tube at a time and replace in as it was before moving to the next one. While you are at it, make sure the 2 sprayers on the front are clean as well. They are either orange or yellow and rubber tubes also feed into the sprayers. After I finished, I replaced the lid. It it still wasn't working, so I tried step 2.
2. Remove the hose assembly from the main handle. 2 screws and 2 bolds (don't lose the nuts from the back). Once the hose assembly has been removed, then lift off the top part of the handle. Once the top is off you should be able to open the front lower part of the handle exposing the additional electrical and more rubber tubbing. In the middle is rectangular looking object. That is the water heater. If you just ran the vacuum, do NOT touch this as it will be hot. Wait for it to cool. check the connections of the rubber tubing and make sure they are clean. In my case the tube going in to the heater was all blocked up with cleaner solution. Once I cleaned that up an reassembled in reverse order, the unit worked fine.
Hope that helps you.
Apr 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Not picking up
make sure it isnt cloged and check to see if the roller brush belt is working correctly
Jan 24, 2009 | Vacuums
I NEED TO CLEAN UPRIGHT HANDLE TUBE IT IS CLOGGED
Its a simple operation but it will take some time.  On the back of the Oreck just up from the motor you'll come to the first rubber ring which hides the push/pin locks of the main spine. There are two or three on the Oreck depending on the XL model - slide them down to reveal the pin locks and push them in wards to unlock the main spindle pipe. At the same time ensure that the bag clip at the bottom has been unclipped and the cord is also free, taken off the hooks at the back. The main pipe/spine at the back is the main dust channel so this is the first place to check for a clog and then upwards towards the handle/dust channel feeder - there is usually a small screw on the square part at the bottom which loosens the main handle from the body of the spine.
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
283 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
