SOURCE: Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
SOURCE: No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
SOURCE: samsung syncmaster 740N 17 inch no display
manual and drivers
http://www.samsung.com/it/function/search/resultList.do?searchWord=913v&ct=0&sort=0
SOURCE: i cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
SOURCE: I have owned a Samsung 932BW a couple of years.
reynolds3d, Nothing new here. Happens a lot. 932BW will need to have some work done to the unit's SMPS probably. Read my fixya profile and make decision on what you will do based on info found there. 12fixlouie
