Question about Oreck XL2200 Bagged Upright Vacuum
I NEED TO CLEAN UPRIGHT HANDLE TUBE IT IS CLOGGED
  • 328 Answers
Its a simple operation but it will take some time.  On the back of the Oreck just up from the motor you'll come to the first rubber ring which hides the push/pin locks of the main spine. There are two or three on the Oreck depending on the XL model - slide them down to reveal the pin locks and push them in wards to unlock the main spindle pipe. At the same time ensure that the bag clip at the bottom has been unclipped and the cord is also free, taken off the hooks at the back. The main pipe/spine at the back is the main dust channel so this is the first place to check for a clog and then upwards towards the handle/dust channel feeder - there is usually a small screw on the square part at the bottom which loosens the main handle from the body of the spine.
Posted on Jan 02, 2009
How do you clean the handle
Tina,
Sounds like you have a clog. You can turn the collars on the handle to be able to dismantle your handle so that you can check to see if it is clogged. hope this helps.
Jun 26, 2012 | Oreck XL21 Bagged Upright Vacuum
My Hoover upright U5472-900 runs but there is no suction at all. I have taken it apart and thoroughly cleaned it.
Turn it on. Detatch the cleaning tools handle from it's mount. If it still has no suction, you have a plugged hose. Everything your vacuum does goes through that long hose. Take the 2 screws off where it attacvhes to the unit, then gently push a broom handle through it to release/loosen the clog. You should be able to see through the hose from end to end. Toys, tissue and pine needles are big culprets of clogged hoses.
Aug 31, 2011 | Hoover U5472-900 Upright Vacuum
My Bissell ProHeat 2X CleanShot Upright Deep Cleaner, 9500; flow gauge will not spin and the machine is not dispensing solution with both the solution and water tank full. I have cleaned all inlets where...
No what it means are the tubes that carry the solutions are plugged and most likely full of old detergent that hardened. You will need to clean all the plastic tubing out for the dispensers. When your done using the machine always run clean water only through the dispenser and tube to flush out the detergents.
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Electrolux Vacuums
Makes a extremely loud alarm sounding noise while vacuuming and the cord in the back doesn't have good suction at all.
When you hear the whistling noise, means there is a clog either in the hose itself, or in the elbow where it goes in or from where the bottom tube bends and goes up. To clean hose, remove it, stick on top of broom/mop handle and push all the way down to clear out any debris on it.
Nov 20, 2009 | Bissell 6591 Power Trak Revolution Bagless...
Dyson DC 24 is clogged, not suctioning. How can I check the tubes for a clog?
I removed the flexible tube sections and blew compressed air in reverse flow path to remove the clog. however I have noticed my vacuum getting clogged more often and would like to know how to clean the insides of all the pipes to remove residue alloing buildup
Oct 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
There is a - and i will call it - a relief valve on the top front of the canister that pops when the handle is released to vacuum - i have cleaned everything like the manual says but did not work -
Im not sure about this relief valve - if its a valve that has a flipable catch on the back of the handle its not always supposed to pop open. Perhaps you could be a bit clearer where the valve actually is? Older Dyson models have a valve on top of the handle where further small cleaning attachments can be fixed onto clean. If its clogged then a wire brush will need to be inserted into the handle to clear the clog thus making the attachments **** up dirt.
Mar 24, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
HOW DO i CLEAN MAIN TUBE IN HANDLE CLOGED
You'll have to unpick or slide up the rubber rings on the back of the handle at the bottom where the rear of the bag is. Unclip the bag so that it moves freely, slide up the rubber rings and you'll find a series of pop locks. Push these in to take out the main dust spine pipe - also remove the power cord at the top of the handle to release the handle. In the middle of the spine there is one screw that bonds the top handle part to the spine, unscrew this so that you can split the two parts up and check for clogs. Also check the main dust channel that leads to the bag - it is notorious for clogging because of its relatively small dust channel.
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
No water or soap flow
Does liquid squirt out of the hose. If it does then probably the heater inside the handle asm. is clogged. Take out the two long screw that hold the top handle on and remove it, then near the bottom of the handle, near the bottom are 2 more screw to remove. Then the front of the handle asm. will come off, pull the 2 tubes off of the heater and check the inlets to make sure they are open. It gets clogged up from calcium from saop deposits, but when you are down with the machine, run vinegar and water mix thru to clean out the lines before you put it away. Let me know if this doesn't fix your problem.
Jan 01, 2008 | Bissell 1699 ProHeat Clear View Upright...
Oreck XL2200 Bagged Upright Vacuum Logo
161 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
