Question about SanDisk Sansa m240 MP3 Player
My earphones keep losing and regaining sound!
My right earphone for the sansa m240 works great, but the left one loses sound when you make a sudden movement, when you are running, or when the car hits a bump. You have to twist the plug/jack and adjust and hold your hand there to get decent sound. But then, if you move, it goes away again? What is wrong with it? Can I fix it?
  • 33 Answers
The wires in your headphones are broke my sugestion is to get a new pair
Posted on Apr 24, 2007
SOURCE:
My earphones are having an irregular volume problem! The left side is much louder than the right side. I know this can't be normal and even tried to fiddle around with the audio jack to see if I could fix...
could be a lose wire in the right side open it up and find it solder it so it strong and will never be lose again if there is no lose wire solder them all and see if that makes a differences if not i dont know wat u can do
Aug 10, 2010 | Bose in-ear headphones - Black with...
One earphone stopped working
not thrased jus yet wire in casing came lose needs to be resaudered
May 13, 2010 | JVC Gumy Ear Bud Headphone - Peppermint...
Left earphone has lower volume than right
Maybe you can try adjusting the plug, or the wire within the left earphone is rusted, or change the sound effects on a computer.
May 03, 2010 | Philips Audio Players & Recorders
Shure earphone problem
There is no fix for that. They will need to be sent to Shure for repairs. Contact Shure Service.
May 01, 2010 | Shure E3C Consumer Headphones
Only one of my earphones work for my mp3 player
Make sure that you've pushed the earphone plug all the way in. Some Sansa players have very tight earphone jacks. If that doesn't work, it's likely that the player is broken.
Jan 28, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
Only get sound through one ear
You can see if there is a balance settings in the equaliser..
Highly unlikely its a setting chances are the earphone female connector on the player is eighter damaged or shorting, simply opwn it up and resolder the pins on the connector.
Oct 25, 2008 | SanDisk Sansa m240 MP3 Player
Sound Only Comes Out Of The Right Earphone
If its less than 1 year old, have it replaced. Its a loose connection on the circuit board. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 24, 2007 | SanDisk Sansa e200 MP3 Player
Earphones stop working
I had this very problem. The Sansa worked great for over 1 year, but then I started getting some dropping out of sound on the left side. Today I went to an electronic shop and they opened up the unit. There was a small crack in the solder of the earphone jack on one side. So the electrician just used a fine point solder and fixed that, then strengthened the other solder points of the jack to make sure it won't happen again... I hooked in the earphones....and it is PERFECT again!!!! So, don't lose hope...just take it in to a decent electronics shop and they will most likely be able to fix your problem. And he only took around US$10 for the job. Beats buying a new player...
Mar 28, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
94 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
