Question about Kenmore 94812 Top Load Stacked Washer / Dryer
Dryer doesn't work
I ordered a new element and installed it and it still does't work.... Element doesn't heat up. Do I have it wired wrong or is ther a fuse?
    President:
  • 878 Answers
Putzer, I give you credit, this is not the easiest job on this model. If this is a 417 model, on the housing where the element sits inside you have a high limit thermal fuse and control thermostat. According to the diagram I have the high limit should have a black and orange/black wire coming from it. These diagrams can be wrong however. Remove the wires from it and test it with a meter, should show continuity. If it is open, no heat. Catriver...post back.
Posted on Apr 23, 2007
You probably need a new heating element. Type your model number + Heating element into Google search. and it should bring up several retailers that carry the part. It's not a hard job to do, just labor intensive. Unplug your dryer, remove the back plate, disconnect element wires (remember where they go or mark them with lettered pieces of tape) unscrew the element. Install: Put wires on new element, reattach element, reinstall back cover, and you're done.
Apr 05, 2014 | Whirlpool Dryers
Whirlpool Ultimate Care 2 LEQ8000JQ3 w/ Accudry- how do I make sure the Accudry feature works properly when I replace element?
The orange wire mounted to the 250 limit at the base of the heating element connects to the timer motor. When the element is on the motor cannot move forward in autodry. When the element is off the timer motor slowly advances. that is how it works. If you small limit on top is blown you have a restriction in your venting system or a clogged filter chute or a bad cycling thermostat. I worked on one and did a video recently. ROPER DRYER NO HEAT VIDEO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2012 | Whirlpool Dryers
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Jun 21, 2011 | Dryers
Dryer does not produce heat.
Heating element has gone bad. Go to appliancepartspros.com and you can order new one. Also this site has schematics of where it is located. Simple to install, unplug dryer, remove back, remove and replace element, usually 1-2 screws and 2 wires. While you have back off, vacuum out all lint from dryer vent and dryer.
Aug 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The old element has 3 wires the new element only
You need to take the high limit thermostat off of the old element. It sits over one of the terminals of the heating element, and has two termnals on it. It should just be one screw to take it off.
Dec 05, 2009 | Roper REX4634KQ Electric Dryer
Procedure to replace heating element on 84152 electric dryer
This is a simple repair. Just follow these steps:
1. UNPLUG dryer. Dangerous voltage is still present even with the dryer turned off.
2. Remove the dryer vent exhaust hose and remove the back of the dryer.
3. The heating circuits are located on the right hand side (as viewed from the rear). The heating element is located inside the heater box. Simply remove the mounting screws on the heater box and remove the two wires on the heating element terminals. NOTE: You can leave the two remaining components (Thermal Cut-Out and Hi limit Thermostat) connected on some models. If you need to remove them in order to remove the heating element make sure you label the wires.
4. Locate the mounting screw(s) on the outside of the heater box that hold the heating element in place.
5. With the mounting screw(s) removed the heating element will slide out of the heater box.
6. Insert new heating element, making sure you avoid touching the coil and align the screw holes so you can reinsert the mounting screws.
7. Re-install the heater box and any remaining components.
Now...are you sure you have a bad heating element? Just because a dryer does not heat, does not necessarily mean the heating element is bad. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The most common fail item that causes a dryer heating circuit failure is a blown TCO caused by poor dryer ventilation. Just something you may consider.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 22, 2009 | Kenmore 84152 Electric Dryer
Electric dryer not heating...works fine, but no heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 04, 2009 | Roper RGS7646KQ Gas Dryer
Wirer hook up for heat element and thermostats
For these two items ther is no order for the connections. you can just hook them back up.
David
May 22, 2009 | Dryers
Heating element stays on when dryer is off.
id suggest you need a new timer. it sounds like the contacts are welded shut and flowing power to the coils
May 10, 2017 | GE Dryers
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
195 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
