Stereo indicator will not light.
Brand new bulb tests fine but no light. Replaced all the fuses and everyhting else lights up beautifully. Is there another fuse somewhere that I am missing? Where should I be looking? sounds fabulous and you can tell when it goes into FM stereo mode but no light.
thanks in advance,
Andre
    President:
  • 624 Answers
What kind of receiver is this, it is very important to know the make and model. You may have a bad transistor or open resistor in the circuit for the light. No way to know anything without more information
Posted on Feb 06, 2009
How do i fix indicator lights on golf 4 2l. 2000 model. Bulbs is fine , bought a new relay , still not working.
Have you tested the turn signal switch is voltage leaving the turn signal switch? I would think it is the switch that is the problem assuming all the fuses related to the lights are ok and not blown out.
Aug 12, 2016 | 2000 Volkswagen Golf
My 2005 matrix keeps blowing 15amp rear running light fuse every time light get turned on all other lights work fine.whats causing this?
fuses blow because of dead shorts or excess current draw
to blow a 15 amp fuse indicates a dead short
by disconnecting the rear lights , the problem is in something else you have replaced
could be a problem in the head light wiring
Feb 05, 2016 | 2005 Toyota Matrix XR
Corolla 2006- both driving headlights dont work,dims work. brights work if lever is pulled back, bulbs have been tested .wiring appears to be fine . all other lights,indicators are fine. car is drive
as positioning the lever in certain positions allows the lights to work then the problem will most likely be in the light switch itself. Replace the light switch unit.
Nov 21, 2014 | 2006 Toyota Corolla 1.6
1997 Ducati 900SSCR ran beautifully up till two wees ago. Went to start it today and nothing happened when I turned the ignition key to "on." Nothing + no ignition lights, no any lights, no fuel...
Hi Mullerr, try doing a voltage drop test starting with the outboard side of your main 30 amp fuse if it is more than 1/2 volt lower than your battery voltage, replace the fuse and for more information about your question please visit the website below. Good luck and have a nice day. http://fullmanuals.com/brand/ducati
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 29, 2011 | Ducati 900 SS Motorcycles
I have a yellow warning triangle on the display panel of my F800GS. It is also displaying 'LAMP'. The low beam bulb wasn't working. I have correctly replaced the defective bulb but the display still shows...
There are no fuses on your bike. Are you sure that all the bulbs are working?? Check the front parking lamp, is it out??
Check all the lamps on the bike including turn signals etc. If indeed there are no lamps out, then there is some kind of problem with the ZFE which is the module that controls the lamps and other electrical loads on the bike.
Maybe time to check the stored trouble codes with dealer computer or a GS-911 scanner. Your bike is likely still under warranty??
Good Luck!
Nov 16, 2010 | 2008 BMW F 800 GS
1999 GMC Envoy: replaced both GE 3057 lamps in left rear light assembly. Lamps both light. However depressing brake pedal does not initiate brake light. The righ rear brake light does work. The high mount...
The high mount brake light has its own fuse, so check that first. The high mount bulb is generally a stabdard type (there may be more than one bulb) or you can replace with an LED. As for the left rear bulbs not working when depressing brake pedal, check the bulbs again for any spring that may be broken. If the bulbs are still good, make sure there is sufficient contact with the socket. If still not working, have someone check it out further.
Feb 15, 2010 | 1999 GMC Jimmy
1986 oldsmobile ciera, signal lights just stoped working, no indicator light on dash even. hazards still work, fuse is fine and relay for hazards was replaced. seems all bulbs are good as well??
there should be a flasher under the dash looks like a metal can in fuse box if this is whst you call the relay then the switch is bad if not replace this it is a 552 flasher
Aug 05, 2009 | 1986 Oldsmobile Ciera
Dome lights won't come on
Check it very careful use a test bulb to verify the fuse connection, sometimes visual checking alone is not enough.
Jun 01, 2009 | 2000 Hyundai Elantra
Electrical problems in subaru - can't get my brand new stereo installed and working
the airbag should be fine aslong as the light is not on. the airbag wires are wrapt in yellow plastic. check all fuses with test light cos the wires for those accesory arn't near the radio at all. there are two power wires for the radio CONSTANT and ACCESORY if you have the two around the wrong way it could cause this problem.
Oct 22, 2008 | 2000 Subaru Impreza
60 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
