Question about Kenmore 44102 Front Load Washer
Black stains on Laundry from a front load washer.
My Kenmore front loading washing machine leaves black stains on my laundry. The inside of the machine is clean and the stainless steel drum is in new condition. I suspect the rubber door seal is starting to rot and is the cause of my problem, but it is supple and I can see no obvious signs of deterioration. Can anyone suggest any other cause and/or a solution? Are these seals available, are they expensive and can a slightly below average handyman remove and replace them?
  • 2 more comments
  • pf29292 Aug 02, 2008
    We have the same grease stain issue (loud spinning but not horrible as described by others) and were told by Sears it's the bearing(s)?. From the MANY posts from people with corroded "spider" and/or aluminum issue, it sounds like they had to replace the whole assembly which I understand to include the bearings. Posters say they've found this assembly for as little as $150, which is a whole lot less than the $850ish Sears wants to charge for parts and labor. Is the "grease stain issue" caused by the same things that's causing the loud noise, knocking, grinding in so many Kenmore 417 frontloaders?
    btw, our water is probably on the soft side and I use little or no softener; a conservative amount of liquid detergent and occasional liquid bleach (I figure if the machine has a dispenser for the stuff, the manufacturer must think it's ok!) Appreciate any input....Thanks!
  • rlhambel Aug 18, 2008
    We have brown stains from our Kenmore front loader, most often on the edges of collars, sleeves, plackets and shirt tails. I have wondered if it is from deeply imbedded dirt coming loose from the deep crevases around the seems of the rubber seal. I have run rags and bottle brushes around the edge, and rund LOTS of soap, bleach, and baking soda through nearly empty washing loads. No success so far.
  • Alex Koop Jul 31, 2012
    MIGHT NOT BE BEARINGS! Had the same probem with black marks on my laundry. Read on the interent it is the bearings!Machine made no rumbling noises, but I had the marks! Contacted my landlord, who send a technitian, who confirmed -> bearings = cheaper to replace than to repair. Landlord bought me a new washingmachine. To my horror there was more black marks on my white laundry with the brand new machine though! Was it the dryer? I called the dryer service and the nice lady told me to check if the drain hose from my washing machine might be inserted too far into the drain pipe. Should only be 2-3 inches. If inserted to far into the drain tube, teh hose can supposedly **** waste water back into the machine! I pulled out the hose and it was all mucky and about 6 inches into the tube. Now that I have adjusted the hose and run an empty wash cycle to clear the hose etc, the next white wash came out ex any stains - RESULT! Just feel sorry that a probably still alright and not so old washing machine has gone to the skip. Wonder if most the black marks = bearing problem posts are facilitated by engineers who just want to sell new machines?!!?
Posted on Jul 31, 2012
  • Michal Knoller May 08, 2013
    Thanks for coming back and writing a solution that worked for you - On too many forums you read problem after problem and never see a solution - Thanks (I haven't triedit yet but I'm hopeful)
    President:
  • 878 Answers
Bob, if your model starts with 417. this is a mother of all jobs. The black marks are coming from the rear bearing assy. in the tub. I just changed one out and it is misery. I don't believe the boot is causing the black marks. When I tore this one apart I found the tub, tub to drain pump hose, pump itself, contaminated with this black crap. Replaced them all. The tub and bearing comes as one piece and it is no fun to put in. The whole washer has to come apart to do this job and it requires two men to do it. The boot (bellow)itself is a pain to install. You might want to check with Sears and see if this is covered under the 5 year warrany on the bearing and tub, parts only, if not, it's not worth the time or money..Catriver..post back.
Posted on Apr 23, 2007
The solution already posted about the bearing on the back of the tub going out is exactly correct. We had the same problem and the washer was under extended warranty so Sears fixed it, 2 men 2 hours both working hard. The only thing I would add is that the high speed spinning sound got very loud at least a couple of months before the grease showed up on the clothes. It's a good warning that unfortunely I didn't pay attention to.
Posted on Jul 29, 2007
I have twice taken apart this front loader Frigidaire washer (also sold as Kenmore and possibly other names) to replace the rotted out aluminum spider arm supporting the spin-basket (which seems to universally fall apart within 5 years), and now I started observing the described black stain pattern on the clothes. As with the spider arm breakdown, this problem has nothing to do with water hardness, softeners, detergents, or dryers (I line-dry all my clothes), and everything to do with the poor quality design of this machine. While I have not yet positively confirmed the cause of the black stains, I suspect that the bearing seal is breaking down and in the process is releasing greasy particles that mix with the clothes and create the described black stain patterns. Unfortunately the repair would cost more than a new machine for most people, as the spider arm is probably just about gone by this stage. I am lucky to own another junk washer for spare parts and am able to fix it myself. For skilled do-it-yourself mechanics, it is possible to find a generic replacement seal and bearings on the internet (40x80x10DL metric seal, 6307-2RS inboard bearing, 6306-2RS outboard bearing) assuming the spider arm is new (over $200 part), or still in good shape. This is a MAJOR repair undertaking, the entire machine has to come apart. The interior of the machine might also be covered with mold and/or soil and/or water deposits that require laborious scrubbing for removal.
Posted on Dec 19, 2010
Yes it's the bearing, and you will have to replace the whole tub inurds. the cause is most likely the deturdgent, you need to use the 1 with HE on the bottle. this is for front loaders. hope this helps.
Posted on Sep 14, 2008
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
My washing machine makes marks on everything
LG WM2101HW 4.0 cu.ft. Washer Stains clothes ruining ...
www.fixya.com > ... > LG > LG WM2101HW 4.0 cu.ft. Washer
... stains out with anything and they are ruining numerous items of clothing. ... stainson light objects ie making white marks on light blue clothes ruining these ... by greasestains from their front loader Kenmore. .... remove the agitator from a ...
Oct 19, 2015 | LG WM2101HW Front Load Washer, White, 4.0...
Why does my front loading washer leave brown stains on some loads?
Hello friend, I appreciate your post!
I see you're getting brown stains on some of your loads of laundry within your Frigidaire washer. I have completed some research in regards to brown stains and that could be iron or manganese in the water supply, water pipes, or water heater. In order to restore discolored loads try a rust remover safe for fabric. Do not use chlorine bleach to remove these stains as it may intensify discoloration. I hope this is helpful. -Matt
Aug 18, 2014 | Frigidaire Washing Machines
My washing machine smells inside the drum. It makes the clothes smell and even though it has been on a self clean cycle the smell is still there. Please help.
Clean your machine by using a cotton wash at 85'C without anything in it, and with no detergent.
Also, empty the coin-trap at the bottom left (front of the machine).
Also, remove the detergent drawer, clean by hand. While the drawer is out clean the dispenser area with mildew cleaner.
You can also try using Sodium Metabisulphite (see a homebrew shop). Avoid using bleach as it damages the stainless steel.
In between washes you can leave the inner door slightly ajar to allow it to dry out between washes.
Apr 02, 2011 | Dyson Memory CRO1 Front Load Washer
Why is my washer leaving black stains on my clothes
It sounds like it might be leaving mold deposits. Try running a cycle with no clothes in it, hot, with a cup of bleach. If the stains are more brown than black, though, that would be rust in the pipes.
Oct 16, 2010 | Kenmore 44102 Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Random brown stains in random loads of laundry
Hi from Australia
Ok the problem with your washing machine is that there is grease and oil stuck in the machine and the oil will dribble out when you run the machine on a different cycle if you rince with cold water then the oil stays in there and the hot water lets a little bit out as it is stuck in the pipes of your machine ok the first thing is run an empty load on full hot water even the rince cycle with 1 cup of bleach nothing else let that go through the long cycle then do the same again with 1 cup of white vinger and 1/2 cup citric acid which you should be able to get over there or baking soda try that it will clean your machine and your pipes it is great way to keep it all clean by the time you have done this you should not have any brown stains
Have a great weekend
Jan 22, 2010 | Kenmore HE2 Plus Front Load Washer
Leaving brown/black smudges
This is most likely caused by laundry getting stuck in the front seal of the washer.
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Brown stains on white clothes in front loading washer
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 44102 Front Load Washer Logo
6,192 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
