Question about Shuttle AB48PN Motherboard
Windows stops booting with new motherboard
Just installed a shuttle AB48PN motherboard and it starts to load windows but stops and restarts
    Problem Solver:
  • 9 Answers
There are probably driver issues, i am guessing that the motherboard is the only change. you can use your windows install CD to boot into windows then install the motherboard drivers from there.
Posted on Dec 28, 2008
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
Can't install windows XP on new hard drive
That problem is from HDD, It can be bad sector on MBR \ on line for boot record\. Change your hard disk , if it in warranty , will be well.
Nov 24, 2011 | Biostar G41D3C LGA 775 Intel G41 Micro ATX...
When my computer starts up after the windows logo loading screen the screen turns black and then my keyboard and mouse stop responding and the screen stays black thats it
Press F8 key after post boot screen and before windows booting, dos screen will come from there select safe mede booting, computer will boot in safe mode
1) Click On start
2) Go to All programs
3) Go to Accessories
4) Go to System Tools
5) Select system restore
Sytem restore window will come there you will select restore my computer to the earlier time, you will get calender on the screen there you have select any highlighted previous date
After restart your computer will be ok.
Apr 01, 2010 | ASUS P4B533-VM Motherboard
No video on boot!
How to Install Shuttle SD32G2 (FD32V1.x) 010a This step-by-step guide describers how to obtain and install Shuttle SD32G2 (FD32V1.x) 010a drivers for Windows.
1. Define your Shuttle System device model.
2. Define your operating system to install your Shuttle System device. Note: Update Drivers in Win Vista
3. Browse System Drivers.
4. Find Shuttle System Drivers.
5. Select Shuttle SD32G2 (FD32V1.x) 010a.
6. Download Shuttle SD32G2 (FD32V1.x) 010a. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install Shuttle SD32G2 (FD32V1.x) 010a.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
Mar 27, 2010 | Shuttle XPC SD32G2 Barebone
Shuttle AB48PN motherboard
i point to jumper you need put it in another place to clear your cmos
Feb 23, 2010 | Computers & Internet
WONT LOAD WINDOWS ON NEW DRIVE
Start or restart your computer. At the Sony screen, press the [Delete] key or whatever key the Sony screen says to make changes. This should take you to the BIOS. Across the top, choose "BOOT" or "BOOT ORDER" and make your optical drive (CD/DVD drive) first. That way, the Windows install disk will get to run first. Press F10 to save and exit. Make sure the Windows install disk is in the drive and follow the prompts to install windows on the restart.
Jun 07, 2009 | Computers & Internet
Boot problems!
Hi gcooper1873,
If your primary IDE has a copy of windows already on it, than that alone can cause the system to re-boot & go into a loop of re-starting. It is alway recommended to install windows fresh when a user replaces the motherboard with a new motherboard. The only execption to this rule is if your replacement board is an exact match of the motherboard. Plat it safe. If you have another IDE data cable replace your current data cable. See if the system restarts.
If you have data on the primary IDE & do not wish to loose the data from your old windows than you need to create a new partition within the IDE's free space. This should stop the system from restarting. You can leave both IDE drives connected for this. Load your Windows XP CD & boot to it.
If the system does not load the Win CD than manually restart the system & press the F8 key every two seconds as the system boots. You should get this screen:
High-light the CD-ROM with the windows CD in it & press enter.
Read the display from windows XP's screens. You want to create a partition within the free space of your primary IDE. Than you want to install windows onto that new partition. By doing this you will not loose any data from your old windows partition. (You'll be able to delete the old win partition later).
Install windows complete & install all of your motherboard drivers from the Gigabyte CD.
Turn on windows firewall for protection. Click on, Activate Windows & do so by phone. Its free.
Update window. (Suggestion, when updating windows look through the updates & find .Net framework 1.0) & install. Its prefered to install all .Net framework's in order. ( 1.0, 1.1, 1.1 hotfix, 2.0, 2.1 ECT). Windows will want to restart your system inbetween some of these. Do so. You will also notice you may have to click on your user ID to log into windows, this will go away after all .Net frameworks have been installed. Do not remove guest from within user accounts in control panel. Once windows updates are finished you can now copy the old partitions data folders to the new windows folders.
Suggested folder's to copy:
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you may have installed.
Now you need to get rid of the old partition with the old win XP on it.
Use windows disk management program.
Click the start button, click on run & type in " diskmgmt.msc " & press the enter key.
You'll need to change the old win partition to a different drive letter. Example: Your IDE drive had one drive letter assigned to it - C:\. Windows most likely kept the letter C:\ assigned to your old windows.
With disk management you can re-assign all your drive letters. Once your sure you have all your data copied over onto the new installation you can delete the old windows partition.
Which one of these motherboards is your's? Click the link below;
http://www.giga-byte.com/Search/Search_List.aspx?Keyword=GA-P31&SearchType=Spec
Good luck gcooper1873!
Any question? Post it here....
Mike
Oct 21, 2008 | Intel Motherboard
Boot up takes too long
This happens when the computer gets full of "junk" (this happens with any computer over time) and can be remedied with a fresh windows install.
If you don't plan to reinstall windows in near future I suggest you go to Control Panel -> Add/Remove Programs and uninstall any software you don't use/need
Also tweaking the system registry migh help speed up boot time:
1. Click ‘Start’ then 'Run’
2. Type in ‘Regedit’ then click ‘Ok’
3. Navigate to ‘HKEY_LOCAL_MACHINE\SYSTEM\Cur rentControlSet\Control\Session Manager\Memory Management\PrefetchParameters\ ‘
4. Right-click on “EnablePrefetcher” and set the value to ‘0′
5. Close 'Regedit'
6. Navigate to 'Windows\Prefetch' folder (usualy drive on C:) and delete all its contents
5. Reboot.
7. Enjoy greatly improved boot time ;]
Hope this helps!
Oct 01, 2008 | Shuttle MS51N Motherboard
Disk boot failure when I installed a new SATA DVD writer
Start the system & enter you're bios & use you're manual to help guide you on this. Go to the Boot section of the bios. You can set the boot order. Normal boot order is like this:
1st boot device, floppy disk (if one is connected).
2nd boot device, cdrom drive
3rd boot device, hard drive
(Drive the has windows installed on it).
Save & exit the bios. The system will restart & windows should load. If it does not, than you picked the wrong hard drive.
Mike
Jun 17, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Windows booting problem
hi sunnyh, when you start up the PC start pressing the F8 key every 2 seconds. A dos like window will load. At the bottom of the list choose, last known good configuration. (win might load the last good configuration) it's worth the try.
If your PC still does not load windows than repeat the above, this time choose, Disable automatic restart on system failure.
This also might allow windows to load (hopefully).
A system that starts going into this restart loop happens for many different reasons. Most common reason was a program that was last installed just before PC was restarted. Second most common reason for restart loop. Added new hardware, bios changes & windows boot files corrupted. If you did install a program, uninstall it. If you were in your bios & made changes, reset the bios. If you flashed the bios, go back to the old bios version. If you added new hardware replace with older hardware.
To fix Windows you may have to reinstall it. Do not run format or you will loose all your data. Even system restore CD's allow for a win reinstall without a format, however if the cd does not allow you to reinstall win unless you do a format. Than windows startup files are too screwed up & you'll have no choice but to format.
All you can do is try the above & cross your fingers.
Mike
Mar 22, 2008 | Gigabyte GA-8SR533 Motherboard
Shuttle AB48PN Motherboard Logo
74 people viewed this question
Top Shuttle Computers & Internet Experts
Alun Cox
pvc73
john smith
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
