Question about Intel Motherboard
Computer turns on but no display/cpu_fan slot not working.
When I start the computer everything starts up all fans the hd the disk drive ect.
The cpu fan only starts up when it is another slot the sys_fan in this case the weird thing is the cpu_fan slot has 4 pins and the sys_fan slot only has three.
I have resetted the video card, memory, cpu fan etc.
I have taken out the bios battery waited and then put back in.
I've tried everything else have been able to find on the internet short of putting a jumper on the cpu_fan slot because someone said the mobo wouldn't start up if nothing was plugged into that slot. I didn't try it because i do not have a jumper.
I'm really out of ideas other than taking it into a shop.
Any help would be greatly appreciated thank you.
  • Anonymous Jan 01, 2009
    Well even when i have it connected to the four pin the computer will still not boot up not even to bios so I can not check it.
    Novelist:
  • 101 Answers
The four-pin CPU fan connector is the same as the three-pin (red is for voltage, black is ground and yellow for the rpm reading) but also adds a blue wire used by some BIOS sets to adjust the RPM speed of the fan. The three-pin will fit into a four-pin connector without modification, using a jumper is DEFINITELY not recommended as it could short your board.
If your system has the four-pin fan, and it boots and runs without error, it may be that your CPU is running cool enough that the fan is not needed at the time. Check your BIOS for a hardware monitor to see the actual CPU temperature. Also, you may have added utilities in Windows to give the fan speed and CPU temperature in real time. You may also notice the CPU fan kicking in when doing CPU intensive operations (virus scans, etc.)
The four-pin fan would run from a three-pin connector but would always run at full speed because the RPM Adjust signal is not present.
Posted on Dec 28, 2008
Procesor failure
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers.
Feb 22, 2013 | Dell Inspiron M5030 Laptop
Inspiron m5030 cpu fan start working but stop working in a few seconds
Step 1:
Feb 10, 2013 | Dell Inspiron M5030 Laptop
Laptop beeps 7 times on start up
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers. Hope this helps.
Jan 23, 2013 | Dell Inspiron M5030 Laptop
Computer started beeping and will not power on
How many beeps ??
Jan 18, 2013 | E-Machines eMachines Desktop PC
When I start my computer, I'll get a black screen with a bunch of text with "American Megatrends" as the header. The screen is unusual, and on the bottom it says "CPU fan error!, press F1 to...
You need to plug in your CPU fan. The CPU fan is VERY important in that it constantly cools your processor, making sure your computer doesn't over heat. If the computer runs and the fan isn't running, the CPU will over heat and cost you hundreds of dollars.
Turn off the power Unplug your computer Open up the case of your computer Find your CPU fan Find the cord coming from it Find the plug on your motherboard labeled CPU fan Plug it in there Plug your computer back in Turn it on
Mar 17, 2011 | iBuyPower Gamer Extreme 573D3 Phenom II X4...
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
P4M800Pro Intel Pentium 4
Sounds pretty much like a motherboard problem. The problem you describe sounds like a RAM problem, probably they are loose in the slot or not snuggled properly. However, since you seem sure its not the RAM, I would consider replacing the motherboard.
Sep 30, 2009 | Biostar P4M800-M7A Motherboard
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
Unable to start - do not get post.
First of all that is too old system that you are using, problems can be your CPU's golden legs are not connected well on motherboard, second your ram memory is not working good, maybe is slower or faster than that motherboard can receive.
First of all disconnect everything from motherboard ...if it does not work :
1. Remove cooler from cpu
2. remove cpu from socket, turn around CPU and look at those golden legs if they are moved aside
3. if they are moved turn them back on the line use needle or small pocket knife to do it and do it carefully
4. carefully place CPU back in socket
5. put CPU protective grease
6. put back cooler on CPU
7. remove ram memory from slots
8. look at the golden legs if there is no broken use clean cotton swabs and pure medical alchohol and clean the ram golden legs put the ram back in slot
9, do the same with your graphics card if you are using AGP slot
10. put back power cable 20 pins and 4 pins
11. Connect keyboard and monitor cable
12. Use screwdriver to shorten the power on pins
If it does not work than you should say goodbye to that motherboard and old technology that you are using and buy motherboard socket 775 or socket AM2 and new cpu and ram its cheap this days to have real dual core computer.
Jul 11, 2017 | Albatron PX845PEV PRO 800Mhz Motherboard
Intel Motherboard Logo
129 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
