Check the terminal connections so that you can fix the audio connections. I have try in the Blockless and its really easy to access and very convenient.
SOURCE: No video when trying to watch netflix on xbox.
Have you gone to My Xbox, System Settings, and selected the appropriate high definition video setting? Do you have it set up on your TV as well? Both need to be set for HDMI.
SOURCE: xbox 360 audio is scratchy
It has to be reflown.. That's the only solution to fixing the audio problems , because its in the motherboard.
SOURCE: I get no audio or video from my XBOX 360
well, you could re-solder the terminal connections, but other than that not really. and if you attempt to solder it yourself and fail Microsoft wont fix it for you.
SOURCE: my xbox 360 turns on, no audio or video
Sounds like the Graphic processor needs to be reflowed and new thermal compound (artic silver 5) installed. Its basically the same problem as the RROD just without the lights.
SOURCE: turn xbox 360 on and no picture on tv
You may need to change your HD settings on the back of the console ( HD setting is actually on cord ) I had that issue when I first went online w/360 . If that does not help u know X box costumer support will repair any damaged system prob. no cost and does'nt take as long as they say.
