1998 Chevrolet Monte Carlo Logo
Posted on Dec 27, 2008
Switch and motor out for sunroof on 98 monte and it's stuck tilte
The switch is brokin and the motor is out. I don't have the money to fix it right now. any way to lower the sunroof by hand
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
682
Points
I had this same problem. I am working from memory, so this might not be totally accurate.
The motor for the sun roof is located right above the switch. Take a flathead and pop the switch out, the whole trim comes out, not just the button!
The headliner is held in place by velcro around the sunroof, and held up by the trim pillars in the front and the top trim above the doors, loosen all this so you can pull the headliner down enough to get at the motor.
If I am not mistaken this motor has a straight-through shaft with a notch in one end, use a screwdriver and turn said shaft until closed.
I got lucky and found an exact match of my '98 monte in the junkyard and pulled the entire assembly out of the car to replace mine. Hope this helps.
2helpful
2answers
Nissan rogue sunroof wont slide open. It will tilt up but not slide
1. Place the ignition switch in the ON position.
2. Push and hold the sunroof switch toward 2 . Once the sunroof has reached the full tilt position, release the switch. Push and hold the switch toward the 2 position again. After a delay of four seconds, the sunroof will make a small movement and backup.
3. Release the switch.
4. Within 5 seconds of releasing the switch, push and continuously hold the switch toward 2 . The sunroof will move from the tilt position to the open position and back to the close position.
2003 bmw 530i sunroof wont tilt or open but i here the motor
If it is not moving but the motor is running then the gears are stripped or the cable is broken . Have it fixed and if you still hate the car then sell it ( you will get more money if the roof works properly)
Sunroof stuck in tilted open position altho motor has power
it probly cam off track if u can get something in there to push it along a little it will probly go down
2003 Kia sorento sunroof- my sunroof is stuck in tilt mode.when I press any of the buttons,it makes a very loud rattling noise. I read somewhere to hold button down for 30 seconds,now its not making loud...
I had this problem and began looking into the solution above, instead we noticed that the motor was really loose. All it needed was to be tightened. We removed the light cover and the entire electronics box to see the motor, which was just two screws then it popped off. Then tightened the two sunroof motor screws, and it worked like new.
My 1990 Maxima's sunroof will slide up and shut,
Is there a way to manually close the sunroof in the up position on a 98 Nissan Maxima?
The sunroof is tilted open and won't close. When
Sounds like sunroof is stuck, motor can't overcome load. Cheap test: car off, interior light turned on try to move sunroof, does light dim? If yes motor is trying to move but can't. If light does not dim then motor not getting power.
My sunroof is stuck in up tilt position an will
If motor is still working you have a broken cable it is a big job have to take out headliner to drop out whole sunroof ***. to change cable.
2helpful
2005 mazda 3 sunroof
H Kim -
The "gearbox" is unfortunately under the headliner with no easy access. If you are also experiencing a clicking sound when the motor is activated, the regulator track had slipped position and will need to be reset.
I have been through this problem twice now. The first time the motor / gearbox came loose from it's mounts, began slipping (click, click,click), very nasty sound. I remounted the motor with threadlock on the screws, but alas.. two years later (mine's 2006) it slipped again.. I don't know why yet, I need to drop the headliner once more and have a look. If you would like a copy of your FSM, drop me a line.
Here's the RESET procedure from the FSM, absolutely gospel, no other way to fix it:
Sunroof Motor Assembly Note: Note • If the guide is removed, initial position setting of the sunroof motor will be required. After installing the sunroof unit, perform initial position setting using the following procedure. 1. Press the TILT UP switch to fully tilt up the glass panel.
2. When the glass panel reaches the fully tilt up position, temporarily release the TILT UP switch and press it again for approx. 13 s continuously. Continue pressing the switch until the glass panel automatically stops at the fully tilt up position after reaching the mechanical lock position.
3. When the glass panel stops at the fully tilt up position, temporarily release the TILT UP switch, then press it again within 5 s and hold.
Note • Press the TILT UP switch continuously until the glass panel opens to the fully open position, returns to the fully closed position and then stops. 4. Release the TILT UP switch when the glass panel stops at the fully closed position.
ALSO, Here's the clearance adjustment specs for having the glass panel in the correct resting position:
GLASS PANEL ADJUSTMENT
1. Fully close the glass panel.
2. Measure the gap and height difference between the glass panel and the body.
3. Loosen the glass panel installation screws and move the glass panel to adjust.
Standard clearance a: 0.2-2.2 mm {0.008-0.08 in} b: 0 mm {0 in} 4. Tighten the screws.
5. Insert any available thin plastic card between the weatherstrip and the body, and verify that they are sealed. (There is resistance when the plastic card is moved.)
• If they are not sealed, perform Steps 3-4 and adjust again.
2helpful
2answers
Camry sunroof stuck
Probably bad switch.
1997 e class mercedes sunroof problem
hello,try to clean the rail,if not corrected,your sunroof motor need to check or replaces if necessary,ty
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
