No sound from aiwa cx nmt320 shelf system
CD player, am/fm radio & tape will not emit sound or respond to controls. The only sound from speakers is pop, buzz, static when power button is turned on. Unit has played all functions fine until a recent power on and the problem occurs. Original purchase about 1998 new from retailer.
Benimur
  • 6966 Answers
SOURCE: Tape recorders.
Most tape problems would be mechanical in nature. I am venturing a guess that the belt(s) are cut. If your brand/model uses two (2) separate motors, then either both belts are cut (unlikely) or the regulator circuitry powering these motor(s) are defective. In some instances, the logic circuitry (especially those with dubbing features) maybe at fault.
Corrective procedures would entail opening the unit for a look and see. This of course would require that you be familiar with electronics circuitry & mechanical components, use of a DVM and possibly even soldering. Should you be uncomfortable going this route, perhaps it will be to your advantage to seek the services of a qualified professional.
Incidentally, should the downtime and cost of repair be no longer economically reasonable, then perhaps purchase of a new unit might have to be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 25, 2008
SOURCE: HOME STEREO SYSTEM CD PLAYER
aiwa cx-na508
Posted on Jul 28, 2008
welcomejee
  • 10594 Answers
SOURCE: AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Posted on Oct 04, 2008
tepfy
  • 319 Answers
SOURCE: Radio 80c7e80b will not play, only get static on AM/FM CD Works
your radio is shot, and the cd and tape player still works. You have to buy a new radio if you want to listen to a radio.
tepfy
Posted on Jun 10, 2009
yungdub
  • 93 Answers
SOURCE: Just static coming from speakers for the radio
Try Installing A New Antenna.
Posted on Jun 13, 2009
Static popping and buzzing sounds come from the speakers when the car is running. The Radio is not turned on and it will continue for a long time, quit then start again as you are driving.
Is it a factory amplified system? Could be the volume knob. Might try unplugging the radio for test purposes and see if it still pops and buzzes to get a better idea of where to go next
Dec 28, 2013 | 2004 Lexus ES 330
Why am i not getting any sound when i hook up a speaker directly up to a speaker channel its only a buzzing sound
If the radio is powered on, put a cd in, or make sure you are on a known good radio station and connect a speaker directly to one of the pairs of speaker wires on the radio. let us know if there is still just static.
Nov 07, 2013 | Farenheit TID735NRBT Car Video Player
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Radio and CD player both emit a hissing or buzzing noise through the speakers like there is poor reception. However, all the local signals are found and play just fine, just the hiss!
The CD player cannot suffer from poor reception, so if you are having the same hissing / buzzing sound from the Bose system irrespective of the source you have selected , its is coming from the preamp / amplifier section.Also could be coming from the electronic source selector in the preamp section.You will need profession help
Mar 10, 2011 | Bose Audio Players & Recorders
Bose Wave Radio, Model AWR1-1W When turned on radio emits a loud buzz and no other sound. Pushing tuning, volume, and aux buttons has no effect. Is this fixable? If so, how?
Loud buzz is usually caused by static and radio interference in radios. If none of this is affecting you unit presently there there is a probability that some cables which aid the fm antenna in receiving stations this could act as static which brings about the buzz on the unit. Either way it is caused by interference on the fm receiver end and all you have to do is get that serviced and the problem is solved.
Hope this solution has been helpful?
Dec 30, 2010 | Bose Wave Radio
I noticed static on fm station on my radio. the
i would get the alternator checked, sounds like its leaking ac current which can also kill the battery
May 04, 2010 | 2006 Subaru Forester
How do I wire my tape and cd player to same speakers?
There are really only 2 options.
#1 Buy a fm modulated CD changer. This will allow you to play CD's over a FM frequency, and will use your factory radio as the output.
#2 Again you can buy a stand alone FM modulator with RCA inputs, and use an aftermarket CD/DVD player as a source.
Aug 09, 2009 | Car Audio & Video
tepfy
Jun 10, 2009 | 2002 Chrysler Town & Country
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
286 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
