Question about Acronis Disk Director Suite 9.0 (ADDS9U) for PC
Copying partitions with Acronis Disk Director Suite ver. 10
With my previous PC, also running Windows XP, I used to copy whole partitions to unallocated space on a second hard drive or external hard drive.
I replaced the computer with another Dell, this a Vostro 410, running Windows XP. The only difference of which I am sure is that this is SP3 for Windows XP, previous was SP2.
Now, Disk Director obligingly leads me through creation of unallocated space and set-up to copy partition, says it is going to do this, boots into its own operating system, reports that it has checked and analyzed the partitions and then boots back into Windows XP without having made any change or any copy.
I have downloaded latest version of Disk Director, removed the old version and reinstalled, with no effect.
Acronis support has been no help. They now tell me that this program will not copy my Drive C partition to any other partition! Their literature clearly says it can. I have copy I made just before switching computers! (It is a copy getting too old to be valuable.)
Does anyone have a suggestion? Does anyone know where I can get knowledgable support?
2 Suggested Answers
richard191
  • 691 Answers
SOURCE: My C: is used for XP OS and apps . It is 20Gb in
Hello
Thank you for using
FixYa for your problem
Acronis generally will make a image to a cd, dvd, or a network drive - I have never tried to a flash drive but if you can I am guessing a 4-8GB drive s/be ok.
Another way is taking the unit into a service centre and they will be able to make a image onto dvd's for you
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 30, 2009
Unitialized corrupt boot structure detected biohd-4 boot path
Apps like Acronis Disk Director Suite and Partition Magic
that might help because they can be booted outside the OS. Sometimes it just cannot be done without destroying the data on the drive. Try one of those!
Jun 11, 2010 | HP Pavilion S3620F Pentium dual-core E5200...
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
Hi i got gx270 and i made a bootable acronis disk director on a flash so i can format ntfs to fat 32 as i tried before to install win xp from a flash drive but got a stop message sayin i should check...
First of all I have to ask why you are trying to load FAT32 instead of NTFS. NTFS is the preferred file system for all Operating Systems after Windows 2000. Also, you cannot format the hard drive through the Windows XP installation for larger than a 32 GB partition. If you need a larger partition, I suggest using a floppy drive with the3 WinME bootdisk loaded on it. You can get it here:
Try the WinMe bootdisk from http://www.bootdisk.com/bootdisk.htm
If the above is not the issue than we can move forward with other solutions.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell OptiPlex GX270 PC Desktop
I used this tool to clone my existing 50G laptop drive onto a new Western Digital 320G. Afterward, the rest of the space on the new drive (270G) was gone. I have deleted and recreated partitions on the new...
you need to resize the partition with a partitioning tool like partition magic or acronis disk director, or clone the drive with acronis true image. these tools are downloadable here. That site has a bootable cd, which is loaded before windows starts.
Nov 18, 2009 | Acronis Migrate Easy 7.0 (AME7)
My hard drive is divided into C and D drives, how do I combine into one?
There is only one way to combine into one partition. Reinstall OS, during install delete both partitions and format HDD
Aug 25, 2009 | Acer Computers & Internet
OS partiton fails,resetup on NEW disc same problem
acronis seems at fault here.its better to keep one partion per harddrive.that way it is't jumping around as many times.use xp to do the partions and see if that works.also make sure *********** board can support the drives terrabyte capacity.also instead of useing the disk defragmenter built in xp use jk defrag it is alot better.you don't even have to install it just unzip and use.can even use off of a flashdrive.if you got any question feel free to email me at gamecrazy944@yahoo.com
Jul 25, 2009 | Computers & Internet
I made a partition using Acronis disk director suite, and i decided to format my dive C, cause i want to have a fresh system again, but i could not access the recovery manager when i press F11 it just...
youll have to install another operating system if you do not have the disks
when you format the c drive you erased the partitions with the recovery, know on many acers
Jul 19, 2009 | HP Pavilion DV6700T Notebook
As I try to convert my IOMEGA hard drive from FAT32 to NTFS, using Windows XP's CONVERT command, it discovers a drty bit on the drive. However, when I test it with CHKDSK, Windows finds no problems at...
Does anyone you know have a copy of any sort of disk management tool such as acronis disk director or norton ghost?
If yes, you can copy all the info that you still want to keep with the disk management software, and then do a total wipe and format.
MS convert will not do a complete job under normal circumstances (at least in my experience), so you are better off using a third party software suite.
Apr 17, 2009 | Computers & Internet
I have 3 Hard Disk Drives and my C one is full and the other two are not how do i mack them all one Hard Disk Drives?
"mack them all one Hard Disk Drive"? do you mean make them into one Hard disk drive?
if you have 3 "physical" Hard Disk Drives, im sorry but thats not possible
but if the 3 Hard Disk Drives are only partitioned you could use any partition manager software like Partition Magic or Acronis Disc Director suite to combine the 3 Hard disk partition into one...
hope this helps
^_^
Jun 20, 2008 | Acer Computers & Internet
FAT32 format, how to do it in Windows XP?
Try using a third party program, like Norton Partition Magic, Acronis Disk Director Suite, or Paragon Partition Manager.
Nov 20, 2007 | Western Digital WDG1C2500N MyBook Premium...
Acronis Disk Director Suite 9.0 (ADDS9U) for PC Logo
103 people viewed this question
Top Acronis Computers & Internet Experts
Marvin
Marvin
tuffbird72
Julie Clark
Julie Clark
Are you an Acronis Computer and Internet Expert? Answer questions, earn points and help others
