Question about HP Compaq Presario V2000 Notebook
LCD Screen is black
I have a compaq presario v2000 laptop. The computer powers up but the screen is black. If I hold a flashlight indirectly on the screen I can faintly see the images. Is this a backlight problem or an inverter? How do I tell?
  • HP Master
  • 32,281 Answers
It could be either, if you can get another LCD screen (same make/model) you can swap to ckeck it out.
You could check the inverter by touching its output and if you get a bit of an electrical shock then you know the inverter is working or check it with a multimeter if you don't like electric shocks.
Posted on Dec 28, 2008
Display problems
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 13, 2013 | HP Compaq Presario V2000 Notebook
The srceen stays black
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 06, 2010 | HP Compaq Presario V2000 Notebook
Would a compaq presario v2000 screen be compatible with a compaq presario v4000 laptop. one of my cats juped onto my closed laptop and now there are two big black blotches and cracks across my screen so im...
Its not compatible. It has different screw listings then V4000.
If you could provide me the product No. which is at the bottom sticker of the notebook of your Compaq v4000 laptop then I can find the part no. for LCD screen which is less costlier and exchangeable.
May 31, 2010 | HP Compaq Presario v4000 Notebook
My Compaq Presario v2000 will turn on but the screen is just black what do I need to do to fix it?
Can you see any image on the screen in a dark room, using a flashlight sometimes helps. An image will be most visible right after you turn the laptop on, when the logo appears. If you can see the image but it is dark you need a new probably backlight inverter which is a relatively easy and cheap repair - I usually charge less than $50. JC Hunter
Nov 13, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2000 Screen went dark
Have you try external monitor? If it's still same, the LCD screen back light or the inverter of the LCD screen was faulty, but yours most likely the inventor of the LCD screen was faulty, it's only can be repaired by components level tech.
Nov 23, 2008 | HP Compaq Presario V2000 Notebook
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Compact Presario v2000 the screen is blank
Remove the power cord. Remove the battery. Hold in the power button for up to 60 seconds to discharge the laptop. Try booting it.
Apr 27, 2008 | HP Compaq Presario V2000 Notebook
Screen went dark
this hapeened due to the fialure of a thn light placed in the screen . it cn be replaced but it cost more. its a flurocent like tube placed in the screen provided in the top of screen
Jan 28, 2008 | HP Compaq Presario V2000 Notebook
Screen display problem
sounds like a loose ribbon cable from the MB to the screen.
Here is a manual that should help you take it apart.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Dec 01, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
