Question about Frigidaire GLEQ642A Electric Dryer
Change fr 3 prongs to 4
Moved to new house. How do I change power cord from 3 prongs to 4 ?
  • Anonymous Apr 22, 2009
    Now what order does the black and red wire go if the green and white are in the center?
  • 135 Answers
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Posted on Jan 28, 2009
  • 423 Answers
I trust the original poster resolved his/her problem. For others, I have an overview. The 4 prong plug/outlet is the preferred connection compared to three prong, but if you have a three prong setup and it is working well, there is no pressing reason the change it. But when you encounter a dryer outlet that has a different number of prongs, here is what you can do. Take a close look at the new outlet (better yet take a picture on your shimmy new cell phone with the camera built in.) Head off to your hardware store and go to the electrical department. You can buy new cords fro your dryer. For this case, we will assume that the new house has a 4 prong outlet, the dryer you brought with you has a 3 prong plug.
Buy the 4 prong cord that matches what your outlet looks like and head home and get cozy with the back of your dryer with the connected power cord dangling down to the floor. Fine where the cord enters the dryer and remove the screws that holds a plate over the cord. Look carefully at the 3 wires that are connected and note the color of those wires and where they are connected. (Take another picture with that snazzy cell phone camera.)
Compare the new power cord with the 'current' one (no pun intended) The major difference is that the forth wire on the new cord is a green wire (Ground)
Remove the three wires from the dryer and replace each wire with the same color wire. If there is a 4th terminal that was not being used, connect the green wire to it. If there is no 4th terminal screw, connect the green wire from the new cord to a screw near by as you close up the plate you removed. It is important that the green wire does _not_ just float around beneath the plate where the new cord connects.
Connect the new cord into the 4 prong outlet and dry your clothes as you see fit. As you push the dryer back in to the way, triple check that the vent tube remains firmly connected to the dryer vent connector.
Good Luck!
Rule: When in doubt, hire an electrician.
Background: The difference between 3 and 4 prong outlets/cords is that there really should be a difference between the neutral and the earth ground when wiring for 240 volt (208 volt in some situations.)
Posted on Apr 03, 2009
Changing power cord from 3 wire connection to 4 wire connection
Hi jdebesch
Go to the following webpage and the pictures will show you how to convert you or 3 wire to a 4 wire connection.
I believe this is what your looking for
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Nov 25, 2012 | Hotpoint Dryers
Maytag neptune endeavor 3 prong electrical cord conversion
Yes this can be done but this is removing the ground wire in the plug which if you have a thunderstorm and a purge comes threw it may blow the board now this is a maybe so it will have to be hooked up L1Black L2 red And white. on the back of the dryer instead of L1 L2 Common and ground. They have operated this way for 20 years. Please rate my solution and leave testimonial it is how i earn my achievements thanks in advance.
Apr 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 | Dryers
I just moved and have a standard 3 prong outlet in my laundry room, the dryer has a 4 prong cord- what kind of replacement cord do I need to buy that will make the electricity of both the dryer and the...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-language: AR-SA" lang="EN">Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span>
Aug 26, 2010 | Frigidaire Dryers
No power going to it. wont turn on. just moved to new place and had to change the power cord from a 4 pronged to a 3 pronged.
you need to make sure that the power cords 2 hot wires(USUALLY BLACK & RED) are hooked to terminals "L1" and :" L2" either wire on either terminal, then the white wire goes to the "N" neutral terminal, usually,but not always in between the two hot terminals, then make sure you have power from the house main panel
Oct 04, 2009 | Dryers
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Frigidaire GLEQ642A Electric Dryer Logo
526 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
