Question about Audiovox FPE3206 32 in. LCD Television
Audiovox fpe2705 inverter board replacement
After some investigating, I've found that I need a power inverter board for my audiovox t.v. (FPE2705). I'm not sure which inverter board to order or the best place to order it from. Any advice is greatly appreciated... I'd also like to get some confirmation that this is the best solution for the problem with my t.v. having sound but no picture. Faint picture is visible when direct light is on the screen.
  • 11,361 Answers
You need to verify first that you do have 24vdc feeding the inverter boards, if you do have 24vdc then we can be sure it is the inverter boards. The inverter board will have very small surface mounted fuses, check for that also.
Posted on Dec 02, 2009
Lcd tv model fpe2705 intermitently will not turn on. Need audiovox service center for out of warntee
HI,
Can you please give the zipcode of your area so that i can find a service center
Apr 24, 2008 | Televison & Video
27 lcd model #fpe2705 no picture only sound
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!@#
Apr 21, 2011 | Audiovox FPE2705 27 in. HDTV-Ready LCD...
Hi my audiovox fpe2705 needs red color in shows only in green an blue thank you
remove back cover then check the CRT tube if there is color red cathode how?by using a wire or test prove connected in ground in your TV very quick if red screen flashes your CRT is good then check your CRT board socket find the driver transistor of red cathode then check it if shorted replace thank you
Mar 05, 2011 | Televison & Video
When I turn on the Audiovox FPE2705, it says the Audiovox logo, but then goes black. It looks like the back light just turns off. I think maybe the inverter or controller is turning the back light off. Is...
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Otherwise indepth troubleshootong required or you may end up replacing the wrong parts.
Please post back what you find.
Nov 14, 2009 | Audiovox FPE2705 27 in. HDTV-Ready LCD...
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Oct 08, 2008 | Audiovox FPE3206 32 in. LCD Television
Flat panel tv
I had a similar problem, except I had sound and with a flashlight I could see audiovox when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Aug 16, 2008 | Audiovox FPE3206 32 in. LCD Television
Audiovox FPE3206
I had the same problem on my Audiovox FPE 3206, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Apr 22, 2008 | Audiovox FPE3206 32 in. LCD Television
No picture
Bad news if you see burned parts the board is a gonner. SMD and very difficult to repair. most time a replacement is the only repair. The board you are looking at is probably the inverter board. the inverter drives the back lights on the lcd display. Some of these boards can be costly. on some of these sets they use combo boards * ie signal and digital and power supply all on one board
Feb 20, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Audiovox FPE3206 32 in. LCD Television Logo
857 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
