Question about Olympia OL5880 Cordless Expansion Handset
Phone keeps searching
I answered a call on morning when i hung up the phone gave a signal of searching. i picked up the extra hand set and that also says seaching. i unplugged and removed batteries still showing same results. i plugged into another working jack and the same problem occurs. is there something in the menu or any way i can reset the phone. thanks Faith Adams
  • G-greg Jan 05, 2008
    phone keeps seaching
  • Brett Duxbury
    Brett Duxbury Oct 05, 2017
    how is the base unit is it powered up and plugged into the phone line ?
I can't retrieve incoming calls. Often the phone keeps ringing after I pick up the handset. My Phone is Uniden 6.0 DECT 1635+1 - 58004699.
change the phone set up to --answer on lifting hand piece
It may have glitched and now requires you to press talk to make the connection
Jan 28, 2018 | Uniden Lands Phones
Are thee any Binatone handsets compatable as extra handset to add to Binatone symphony 3325 unable to get new handsets but main answering machine and handset are still working
with cordless phones the problem is that the hand sets have to be recognized by the base station ( paired) and unless you have the exact hand piece make and model this pairing and recognition will not happen
if you can get 2nd hand units for the 3325 base then the base will accept them ( any number of additions ) but if the hand piece is different it will not work
you you need extra hand pieces then it may be best to consider a new system where you can buy extra phones and chargers
Jul 13, 2016 | Binatone Lands Phones
When I am on the main base phone and someone picks up a hand set and dials out, I can not hear the person speak nor they me. This only happens during the push button dialing out with the hand sets.How do...
stop trying to dial out, you can't anyway if the phone s being used. the reason you cant hear when buttons are pressed is because they bleep to send a signal to the exchange which will over-ride the other phones.
Nov 04, 2013 | AT&T DECT 6.0 Cordless Phone System with...
HOW CAN YOU USE A MERLIN MLX-10D AS A SINGLE LINE PHONE FOR A FAX MACHINE?
For the most part, the answer is "you can't". An MLX phone's extra port can operate a 3156-MFM module and derive the extra extension. There may be some conditions, like no DTMF receiver, and a few other problems.
I didn't ever sell one, but here's a link to a search http://www.google.com/search?q=3156-mfm&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
You can pick one up for as little as $50 on eBay.
Carl
May 04, 2010 | Lucent Merlin Legend MLX-10D Phone
Answermachine not picking up
I emailed Motorola support. Email bounced back and was redirected to their broadband support. Not what i needed at all. Tried again, same result. Gave up in the end and contacted BT who round a fault at the exchange which was blocking my Caller Id. Once they fixed this, the answer machine worked too. Weird. Especially as I plugged in an older phone earlier to test it and the answer machine on that one worked. Nil points to Motorola for support I have to say....
May 28, 2009 | Motorola Lands Phones
Disabled phone line
Sounds like the answering machine is picking up the telephone line and not releasing it.
Hence the busy signal, cause the answering machine has the line off hook. It's like leaving your telephone off hook, the next caller will get a busy signal...
The answering machine might be bad... have you noticed that you were talking on the phone and hung up then the next call would be the busy signal? Maybe test this out.
Do you have the correct voltage to the answering machine, too much power or too little power can do funny things to telephone equipement.
May 12, 2009 | AT&T Lands Phones
NEED THE MACHINE TO ANSWER WHEN THE PHONE SENDS THE SIGNAL.
After making my post, I went to the official Brothers website for the 4100 FAQs and "Operating Instructions." Here's what I found. Set your 4100 set to the "Fax/Tel" mode. Press "Menu", then the number 2 (Fax), then number 1(Set-up Receive), then number 1 again (Ring Delay). Use right arrow key to increase. Once increased, press the "Set" key. You'll see the message "Accepted." Now press the "Stop" key to exit "Menu." This will now give you up to 4 rings before the fax auto answers. Inorder to send a signal by phone to remote start the fax just follow the instructions I copied directly from Brothers instructions for the 4100: If you answer the call on an extension phone (this is any phone plug into a phone jack on the same line) and hear a beep every 3 seconds (automatic fax) or just silence (manual fax), press *51(remote activation code) on the telephone keypad, wait to hear the Brother machine turn on (chirping sounds) and then hang up. I don't have anyone that can send me a fax right now to test it out. I'll have to try it in the morning. Hope this works for you.
THEOH
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
LIne In Use/Answer On Message
Just some Tips - Do you have any other phones or fax machine in the house? Check to make sure they are all hung up or press the off/ hang up button. If so, disconnect them until one brings back a dial tone when disconnected Also try cleaning the charger contacts with an eraser to the charger sends a signal that the phone is hung up.
Hope this helps!
Apr 27, 2008 | Uniden Cordless Phone
Olympia OL5880 Cordless Expansion Handset Logo
81 people viewed this question
Top Olympia Lands Phones Experts
ray gallant
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
