Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
New front load washer shakes my whole house
The spin cycle is going to shake the beams loose in my houseand my washer moves halfway across the room
  • joshoe Feb 04, 2009
    our washer shakes the whole house and moves across the room
  • 640 Answers
Remove the shipping material...read install instructions that came with owners maneul
Posted on Dec 28, 2008
I have a front loading samsung wf337aa, when it goes into the spin cycle it shakes so bad that it walks across the room. What would cause this?
Is the washer new? I had same problem it walked all over the room,then i found out it had some long shipping screws in the back that i had never removed,they needed to be taking out before first use, i believe it was 4 long maybe 5" long and each had a plastic spacer also meeds to be removed..good luck.
Sep 13, 2012 | Samsung WF337AA Front Load Washer
Shaking and moving washer
my washer shakes when its washing clothes
May 23, 2010 | GE WPXH214A Front Load Washer
Model WFW83005W05, Serial HLY1329780. It shakes the whole room when spinning, even when we put it on the lowest spin.
There are springs that hold the tub in a balanced position. If they're loose the spin cycle will shake the washer too much. The springs can be tightened with a wrench and stop this from happening.
Jan 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Shaking during the final spin
cement counterweight inside case might have come loose or fell out
Aug 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Nepture washer shakes across floor
iff you remove the door assy 2 screws holding it on) andthe n the 2 screws opposite the hinge, youll be able to remove the front cover and look at the inner workings of unit, perhaps a shock absorber has broken causeing the vibration
Feb 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
215 people viewed this question
Dan Webster
Dan Webster
Sal De
