Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
I have installed silencio850second hand
By ladenzah on Dec 27, 2008
I have installed silencio850second hand purchase, can hear water and heater elements are glowing red so we have heat but no dishes get washed,there appears to be no water in the machine everything is connected and open.
Comments:
Dec 27, 2008
- the first answer is no good I have silencio 850simpson
Dec 27, 2008
- that manual I have it is not an installation manual
Solution #1
posted on Dec 27, 2008
Somewhat Helpful)
machadojr_fe
Rank: Guru
Rating: 86%, 268 votes
ocate your dishwasher's water inlet valve. It should be located behind the lower kickplate panel in either the right or left corner. There will likely be two screws either on the top of the panel, or on its bottom. Remove these two screws, and then remove the kickplate. On some dishwasher models, the door has to be opened in order to gain access to, and remove the kickplate's screws. Close the door before you remove the kickplate panel.
You will be able to identify the water inlet valve by the hoses that connect to it. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now is a good time to inspect your dishwasher's hoses, to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses. Kinks can impede the flow of water.
There will be two wires connected to the water inlet valve. If your dishwasher's water inlet valve has two solenoids, then there will be four wires. Label the wires so that you will be able to correctly reconnect them later. The wires are connected using slip-on connectors. Grasp the connectors and pull on them firmly in order to disconnect the wires from the valve's terminals. Do not pull on the wires themselves. You may want to use a pair of needle nosed pliers to help you.
Use your multitester to test the valve for continuity. Set the device to the ohms setting x 1. Touch each of the meter's probes to a terminal. If you receive a reading of infinity, it means the valve's solenoid is faulty and the valve needs to be replaced. If your valve has two solenoids (four terminals), test the second pair of terminals in the same manner. If either pair of terminals receives a result of infinity, replace the water inlet valve.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
crayzeetrayn
Rank: Guru
Rating: 86%, 434 votes
Heres a user manual
Comments:
Dec 28, 2008
- You said that this is a 2nd hand unit. Was it bought from and individual or its a refurbished/2nd hand unit from a retail/discount store/center?
Do you KNOW that it worked/works prior to you acquiring it?
Was this helpful?
Yes
No
Solution #3
posted on Dec 28, 2008
Not Rated)
Ronnieh49
Rank: Wiz
Rating: 82%, 1574 votes
if you bought it scond hand there would have been no asurance that it worked. you might want to check the lines and all the connections but i think you nought a bad machine
Was this helpful?
Yes
No
Solution #4
Not Rated)
classyexpert
Rank: Master
Rating: 69%, 68 votes
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Was this helpful?
Yes
No
Solution #5
Not Rated)
abhishek33
Rank: Wiz
Rating: 75%, 449 votes
HI
Step 1: Make sure that the water supply to the unit is turned on and that there's no problem at the water heater. A shutdown of the water heater would cause a shutdown of the water to the dishwasher.
Step 2: Check the timer to make sure it's working through its programmed sequences. If both the water supply and the timer are in working order, the problem is probably in the inlet valve.
Step 3: Check the inlet valve located under the tub of the dishwasher. Malfunctions of the inlet valve may also occur when a screen inside the valve becomes clogged with mineral deposits. To solve this problem, pry out the screen with a screwdriver and flush it thoroughly with running water. Then replace the screens.
Step 4: If the valve is controlled by a solenoid, the solenoid is usually connected to the side of the dishwasher. Tap the solenoid and the valve lightly with the handle of a screwdriver to break it free of any obstruction. Then start the dishwasher again.
Step 5: If the dishwasher still doesn't fill, test the solenoid with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect one electrical lead to the solenoid and clip one probe of the VOM to each solenoid terminal. If the meter reads from about 100 ohms to 1,000 ohms, the solenoid is functioning. If the reading is higher than 1,000, the solenoid is faulty and should be replaced.
Step 6: If necessary, replace the solenoid with a new one of the same size and type. Connect the new solenoid the same way the old one was connected.
Badly worn or misshapen inlet valves cannot be repaired. If the valve is damaged, replace it with a new one made for the dishwasher. The valve is usually held to a mounting bracket with screws. Take apart the connection linking the valve to the water supply. Then take out screws and remove the valve. Install the new valve by making the connections in reverse order.
Comments:
Dec 27, 2008
- Accumulated detergent from prior washings can cause problems with the soap dispenser. Buildup can get into the soap dispenser and interfere with the spring that triggers the flip-out tray, or it can slow down the pivot action of the tray. If the dispenser is not opening, first make sure you aren't loading the machine so dishes or pots and pans are touching the dispenser, and that dish racks aren't blocking the dispenser. Also check to make sure the dispenser tray isn't cracked. If leftover detergent in the tray is almost liquid, rather than just damp, the tray may be damaged.
If you can't solve the problem easily, replace the entire dispenser unit. This is usually easier than trying to disassemble it and replace separate parts. Use a new dispenser made for the dishwasher. The screws holding the dispenser in place may be on the front of the unit, or you may have to remove the front door panel to get to the screws and make the replacement. Remove the old dispenser and secure the new one, connecting it in the same way the old unit was attached.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
My global 300 wont start, it original started and rinsed but then stopped and wouldnt restart... (More)
Answer
Hello, I had a sewer line back up that overflowed into my sink onto the floor. I have cleaned... (More)
Answer
Our LG LD12AW2 has just had water flowing under from under the door and all over the floor. Seemed... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
