Question about Behringer (UCA202) Sound Card
Behringer uca 202 not recording
Uca 202 only picks up microphone...do I set it on the CD Audio or Stereo Mix to record from a tuner? Also the meters wont dock.
  • Anonymous Feb 06, 2009
    yes
  • 167 Answers
I also had trouble at first,and fought with it all the time! as it is not a great item. my recording software could not set it up, as it is not actual hardware.(audio codec) make sure the controls are not muted and the slide bars are set upwards. also the drivers from behringer are not signed! and could cause stability issue. you may want to do as i did and get a better unit, (about 20 bucks more) hope this info helps, good luck!
Posted on Feb 12, 2009
What inputs do I use to connect my laptop to the gemini cdm 3700g?
if it's to record the Audio you need some kind of interface analog(RCA ) to usb like the behringer UCA 202 Now if it's to watch or to try to record Audio and Video you need to look at a video capture type of interface composite audio video to interface like the SIIG USB 2.0 Video Capture Device just make sure its compatible with your OS. Now if you try to use it as a Midi controller with program like Serato , Virtual dj ... you are out of luck this system is not compatible .
Good luck.
Jul 05, 2014 | Gemini DJ Gemini CDM-3700G Dual CD Karaoke...
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
Dec 03, 2013 | Televison & Video
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
Super usb cassette capture
You have to convert the cassette's analog audio to digital. Get a Behringer UCA 202 for $30 on Amazon.
Aug 20, 2012 | Audio Players & Recorders
Why cant i hear anything when i recored a video
1. Maybe your sound is off...
2. Bad speakers?
3. If you recorded, do you have a microphone?
4. Check your sound. Right click the sound icon in your taskbar and select recording devices. See if stereo mix is your default. What stereo mix does is record sound from your computer, not your microphone. Instead, set your microphone as the default recording device and try recording again.
5. If you are still clueless, and this is not working, you might have software issues, and need help from your OS provider.
Feb 04, 2011 | Computers & Internet
How to connect mixer 100 fx to uca 202 and laptop
Just connect:
one output from 100fx to uca202 line in. Connect an output that corresponds what you want to get (e.g. if you're going to record something use record out or main out)
one line input from 100fx to uca202 line out.
the USB cable from uca202 to your laptop's USB port.
The solution is the same (in general) whatever mixer you may have.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"????????? ???????"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Dec 03, 2009 | Behringer (UCA202) Sound Card
Cant record audio
you need to select the audio input device as internal stereo mix.
Aug 11, 2009 | Gateway D-Link DI-604 Cable/DSL Router...
I inadvertently deleted the Line-In Realtek High Definition Audio
Simply re-install the software and all your original data will be restored. If you purchased a downloaded version, go to the site from which your purchased it and request your keycode again, and permission to re-download. Then burn the text file with the keycode and the downloaded installer onto a CD so you won't lose it again. Another solution is to get Nero.
Jul 17, 2009 | Roxio Creator 2009 Ultimate for PC
Tried to use mic, only picking up computer sounds.
Ensure that you have selected the Microphone or the Line-in as your recording input. It sounds like you have set STEREO MIX as the recording input. Double click your speaker, select from the drop down "Properties" then Adjust volume for (RECORDING) select that and ensure that your appropriate recording device is selected. (XP)
Jun 30, 2009 | Dynex Audio Players & Recorders
Samson C03 Microphone using with Realtek HD Audio Manager
SEU MICROFONE PRECISA DE UM RECURSO CHAMADO PHANTON POWER QUE NADA MAIS é DO QUE UMA ALIMENTAçãO DE 48 VOLTS, PORTANTO NECESSITA DE UM APARELHO INTERMEDIARIO, COMO UMA MESA DE SOM COM ESTE DISPOSITIVO OU UM ADAPTADOR PHANTON POWER COM SAIDA USB PARA O SEU PC, NO CASO DA MESA TAMBEM é NECESSARIO UMA PLACA DE AUDIO COM CONEXãO USB EXEMPLO UCA 202 DA BEHRINGER , PODES CRER Só ASSIM FUNCIONA E SOM é MUITO BOM.
Apr 06, 2008 | Samson C03 Professional Microphone
Behringer (UCA202) Sound Card Logo
477 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
