Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Rlp 30 won't stay lit after holding control button 30 seconds
Rlp 30 will not stay lit after control button is held in 30 seconds.
cleared line of air, cleared unit.
  • mkas10 Dec 29, 2008
    I have the same problem with a one year old Air Pro, RLP40 unit, made by Desa and sold by Home Depot. Desa has not responded to my repeated requests for assistance and Home Depot no longer handle that product....believe that it is now the Reddy Unit. My unit lights fine and shuts off as soon as I take my thumb off of the button during the starting process, even after after a minute.
  • DrMainprize Jan 06, 2009
    I have this problem as well. Tried new propane tank, cleaned lines, and cleaned flame sensor but still cannot get it to stay lit after I release the control knob.
    Please post your solution if you find one.
    President:
  • 3,433 Answers
Chk and make sure the thermocoupler bulb is in the pilot flame, If it is, it is defective and needs to be replaced. Easy, inexpensive repair. Good Luck, Ned
Posted on Nov 11, 2009
Why is gas furnace in igntion lockout due to recycles (8 blinks). likely causes?
Check the thermocouple (heat sensor) on the pilot light...it tells the control unit that there is a lit flame...otherwise, the control unit won't let the gas valve open...does the pilot light stay lit after you've held the button down 30 seconds?...
Jan 01, 2015 | Dryers
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
My Compaq 172 monitor won't stay on but for maybe 30 seconds then goes blank. When it does this, the on/off button is still lit up, but I have to lush it manually to get it back on for about another...
Failing Power capacitors. The capacitors hold the charge necessary to build up the voltage that lights the screen. When they leak or fail to hold the charge, the screen will cut out. It could also be a fault in the switch circuitry. Really needs looking at by a qualified technician.
Jul 21, 2011 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
I've misplaced my users manual for my Stanley J5C09 jump starter
Go to www.baccusglobal.com and link the Stanley link and then the "manuals" link and it should be there
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
Avaya Partner line always lit
If the line button is lit then something within the system has picked it up. If the phone is a multiline set, the line 1 light on the set that is using the line will show green. The line could also be held by either a cordless phone on the system or the voicemail system. The easiest way to clear the line (if the held set isn't apparent) would be to cycle down the power to the phone system for a moment. That will clear the line if its held by the voicemail
Jun 02, 2010 | Avaya Corded Phone avaparp18d
Wont stay lit
Yep, sounds like you got it. Unscrew the fitting at the gas valve and take the thermocouple to a reputable Propane Gas supplier. They can match it up for you or you can order one off the internet.
Oct 26, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
414 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
