Question about Canon PIXMA MP530 All-In-One InkJet Printer
I need to set up my fax machine. I set it up once but i cant fax anything and i have lost my manual
    President:
  • 1,073 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13371
There u go! On that site you will find the manual, and a lot of other usefull things about your MP350
Good luck to you
If you fiind my answer helpfull, dont forget to vote
Posted on Dec 27, 2008
I can send fax but cant receive them, i need to get settings but have lost manual.
I believe the problem you are having is because you're attempting to use a band saw to send a fax. Although I may be mistaken, I'm pretty certain that attempting to send a fax from a band saw is analogous to trying to get to the moon by using a spatula. I would recommend that you try using a fax machine to send your fax. Hope that's helpful! :)
Jul 17, 2011 | Saws
Lost the Copy and Fax Receive Function
Hi Vic,
I'm sorry to say your fax machine has a bad LASER unit. A laser error code will stop all print functions. The laser units are no longer available.
Sep 15, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Cant get to the phone before the fax kicks in!
You CAN set the number of rings on that machine - but only to 4 I believe. But you can also set it to "manual receive" so that you have physically pick up a phone, and the select 'start' on the machine (when you hear a fax tone), or you can set it to 'Fax/Tel', and have it determine what is a fax call.
Check your manual, because there are several features available that you're obviously not familiar with, and anything else you buy is going to be just as complicated, and probably won't do anything more than this unit is already capable of. You need to read the manual, and figure out how to use it.
Download the user guide here:
http://welcome.solutions.brother.com/bsc/public/us/ca/en/doc/manual_index.html?reg=us&c=ca&lang=en&prod=mfc7420_all&type2=5&flang=English&dlid=
Please rate solution :)
May 04, 2009 | Philips PPF-531 Plain Paper Thermal...
My machine stopped recieving faxs.
Not familiar with the procedure to set your machine, so refer to your manual if need be, but somehow you machine has been chnged from "automatic receiv" to "manual receive", or "telephone mode".. Setting obviously needs to be "auto" for the machine to pick up on it's own.
Often times, this is a button right on the operation panel that you can toggle between the different settings.
Feb 24, 2009 | Brother Office Equipment & Supplies
I have my husband's Panafax UF 895 fax which I am using since my other fax broke. We set it up, but he can't find the manual -- I can fax out and copy, but can't receive faxes. On the display it says...
Your machine is set to Manual Receive.
You need to change Function 17 to 2.
Go to Fax Parameters on the below link to help guide you through programming the fax parameters.
Basically, you hit FUNCTION, then #7, Press #4 and Set,Enter 17, hit Set, enter 2, Set. After you are done, then press STOP, and your machine should be set to AUTO RECEIVE.
Here is a link for the user manual:
http://www.best4systems.co.uk/_design/best4systems/_pdf/Faxes/Panasonic/Panasonic_UF885_UF895_UG.pdf
You should probably save a copy of the manual on your computer incase the link is lost or shut down in the future.
I hope this helped.
If you have more questions, please repost again and remember to leave a rating if I have helped you.
Good luck.
Mac =)
May 02, 2008 | Office Equipment & Supplies
HELP
We also have losted our manual and need to reset everything but can't rember how to do it.. Can someone please help me out on this problem. Very much appreciated!!
Jan 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Samsung Fax machine - not working
Sounds like the machine is trying to talk to the computer make sure the function is set to fax mode this will be in your manual.
Once you have tried this try sending a fax see what happens.
Hope this is some help to you please rate me.
Cheers
J
Dec 07, 2007 | Samsung SF-5100 Plain Paper Laser Fax
I want to set up a Sharp Fax.
Here is your user manual show your apprication by rating FIXYA
Nov 30, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
Unreceivable
Manual can be found here: http://www.samsung.com/support/productsupport/download/FileView.aspx?cttfileid=526982&type=Multi+Function+Printer&typecode=16&subtype=Laser+MFP&subtypecode=&cmssubtypecode=1601&model=SF-5100I&filetype=UM&language= Does the unit ring at all? If it does do the following (taken from the manual) Receiving automatically in FAX mode 1. Press Rcv.Mode/Contrast until the display shows ?FAX MODE?. 2. When you get a call, the machine answers the call on a specified number of rings and receives a fax automatically. You can change the number of rings. See ?RINGS TO ANSWER? on page 5.4. To adjust the ringer volume, see ?Adjusting volume? on page 2.8. If the phone is not ringing, then the call is never even getting to your fax machine. Hope this helps If you need more information, please ask before rating this solution. Ed
Jun 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
104 people viewed this question
old marine
old marine
