Question about Audiovox Jensen Jp 20 Single Outlet 160 Watt Dc To Ac Power Inverter (Jp 20, Jp20)
Jensen 160 watt power inverter blows fuse in car when turned on. It makes a sound that varies between two tones and then the fuse blows. Fuse on the inverter is OK. It worked fine previously. Why would it blow the fuse now?
2 Suggested Answers
  • 25 Answers
SOURCE: power inverter blows fuse in car
overloading fuse on cars wiring try direct connection to battery
Posted on Feb 18, 2009
Outlet fuses keep blowing with inverter use
it could have a fault and thats why it's blowing the fuse, inverters can wear out and the parts may need replacing the capacitors the voltage regulator chips all these parts have to be taken into account, this parts don't last for ever they need replacing. capacitors can last upwards of 12000 hours but electric jolt and what you are use to be powered adds more drain on the electronics most inverters you can get at most 5 years out of them but it really depends on what you use on them, and if you useing it to its max or near max all the time it will wear out, then blow fuse
Jun 21, 2017 | 2000 Dodge Grand Caravan
My inverter keep blowing 40 amp fuses without load
Hi Trevor,
A 1000W can barely supply 5A at 220V, less than 10A at 110V. So if a 40A fuse blows, there is a serious problem and you should not attempt to use this unit after it has been checked by a qualified person. Please be careful!
Nov 20, 2011 | Sunforce 1000 Watt Pure Sine Wave Inverter...
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
My name is Gena. The VEC024B that is being used by our field technicians are having problems with the fuse blowing in their work vans. Their vans are equipped with laptops.
Hi Gena, the inverter is a 400 watt unit. This is not a rating for a continuous load. You do not mention which fuse is blowing. This could be the fuse in the inverter or the cigarette lighter (power source) fuse. In either case, a fuse blowing could be a short circuit, something in the inverter shorted, or too much load. I am going to look at the too much load side of things. Not knowing how many laptops are being used, with the inverter if you have a 20 amp fuse in the cig lighter, this will allow you 20 amps X 12 volts = 240 watts. I would not run the inverter over 240 watts because of overheating issues. So, 240 watts will run 3 laptops. Just the laptops. Most laptops draw around 70 watts. check your power supplies on them to find their rating. If you exceed the 240 watts by combining the ratings, then you can expect trouble with your inverter. It will give 400 watts, but this is a temporary condition only. Another inverter will be needed or a larger one installed and it being connected directly to the battery (with a fuse of sufficient size installed). You could also (let us say there are 6 computers) charge and run 3, and the other 3 are running on their batteries. After an hour, switch so that the 3 running on batteries now are charging as well as running. The other 3 are now charging.
I hope this helps. If you have any other questions please provide additional information. Such as the size and location of the fuse blowing. The laptop power supply ratings.
thank you
Oct 15, 2010 | Vector VEC024B MAXX SST Power Inverter
My 400 watt inverter will not charge my laptop the fuse keeps blowing?
Your laptop PS has big condensers in the input. Even supplied by mains through 6A quick fuse or automatic breaker it will drop first time, but may hold the second. Your inverter may be has fast fuse 2 - 5 A. If not so fast it may carry the initial load.
Hint: If you are not "both left handed" you can connect  20 - 200 Ohm (2 - 10 W) resistor in series to your Laptop Power Supply. After the initial start of the inverter you can shorten the resistor by a 3 - 5 A switch.
Jul 01, 2010 | Vector 1000w Power Inverter
When I turn microwave on it blows 60 amp fuse
60 amps times12 volts = 720 watts times 80% effic of conv. = 576 watts available for microwave...
You must have a very tiny microwave as most require at least 1000 watts input power. That might have something to do with blowing the fuse. Since the microwave has a very reactive inout, you need a goodly safety margin above the rated watts input.
Jan 10, 2010 | Cobra Electronics - Others
Fuse missing
I would start with a 1.5 AMP fuse (175 watts / 12 VDC = 1.6 amp)
Make sure the fuse is rated for at least 120 VAC. Hope this helps!..Gary
Mar 10, 2009 | Dell 175 Watt Power Inverter Car Adapter...
Fuse blow as soon as it plug it in
sounds like your inverter has died :)
Jan 21, 2009 | Car Audio & Video
Power inverter blows fuse in car
Dec 27, 2008 | Audiovox Jensen Jp 20 Single Outlet 160...
Power on
you must use same cable used to power sound unit.
also check if the sound may have a remote connector.
Dec 04, 2007 | Jensen XA2150 Car Audio Amplifier
Audiovox Jensen Jp 20 Single Outlet 160 Watt Dc To Ac Power Inverter (Jp 20, Jp20) Logo
416 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
