Question about Momentum Development UConnect Serial Adapter
Uconnect hands free problem in Jeep Cherokee
2007 GrandCherokee with bluetooth uconnect hands free system. My present phone is audiovox xv6800; prior phone was samsung i760; carrier is verizon. Both phones have same problem: The phone connects by itself repeatedly, it automatically mutes the sound system and I cannot make or receive calls. I have to shut off the bluetooth on the phone to disconnect it. When I turn the bluetooth back on, it reconnects by itself. When it is working, everything if fine. I can't find anyone with the same problem, let alone a solution. Thanks.
I can’t download my iPhone 8 phone book into my 2012 Grand Cherokee Uconnect.
Turn iPhone Bluetooth On:First you want to make sure that Bluetooth is functioning on your iPhone. Click on the Settings icon from the iPhone desktop. From the settings screen click General to show the iPhone General Settings as displayed in the below image. Notice you can see if Bluetooth is on or off from this screen. General Settings screen you can click on Bluetooth to configure the Bluetooth settings. On the Bluetooth screen shown below click to the left of Off to turn Bluetooth On.
  1. Begin Uconnect Setup:Now that Bluetooth is operational on the iPhone you can start the Uconnect process. Click the Uconnect button on the rear view mirror to begin. The voice from the Uconnect system will ask you to verbally select one of the options from the menu. Once Uconnect asks for your input say "Setup" to begin the process of syncing the iPhone.
  2. Start Phone Pairing:Once you say setup in the above step the Uconnect system will list numerous options available from the setup menu. One of these options is "Phone Pairing" so when the Uconnect system asks for the choices from the setup menu say "Phone Pairing".
  3. Pair a Phone:In the Phone Pairing menu you can modify current entries or begin pairing a new phone. After Uconnect lists all of the choices you should say "Pair a Phone" to begin the process of pairing the iPhone.
  4. Uconnect Pin Code:The first step in pairing a phone is setting the Bluetooth Pin Code that authorizes that phone to pair with the Uconnect system. When asked for the Pin Code say any four digit combination such as "1 - 2 - 3 - 4". Uconnect will repeat back the Pin Code so you can verify it has recorded properly.
  5. Connect iPhone To Uconnect:After you have set the Pin Code for the Uconnect system you need to view the iPhone's Bluetooth Settings screen which you can get to following the steps in Step 1 above. Before the Uconnect system shows up in Bluetooth the Bluetooth Settings screen will look similar to the below where you may have other Bluetooth devices showing or not.After a couple seconds the Uconnect system will display as "Hands Free" as shown in the below image. Notice it states that it is not yet paired,,,,,
  6. Click on the Hands Free device showing in the Bluetooth devices list above. This will open a new screen as shown in the below image that prompts you for the Pin Code you specified in Step 5.
    Enter the Pin Code and then click the Connect button in the top right corner of the above window. This will pair the iPhone with Uconnect and take you back to the Bluetooth devices screen where the Uconnect Hands Free device will now show Connected as shown in the below image.
    After the device is connected you will be prompted by the Uconnect voice again so proceed to the below steps.
  7. Phone Name & Priority: After connecting the iPhone you will then name the phone and set a priority between one and seven. Name the phone anything you would like and if this is your primary phone set the priority to one so this phone always connects at a higher priority than any other phone.
  8. Verify & Test:Now have a friend dial your cell phone while you are in your car to see if the music volume lowers and the Uconnect voice tells you there is an incoming call from a certain number. To make calls you can press the Uconnect button and follow the voice prompts.
  9. The Uconnect system is a great way to safely use your cell phone in the car.
Jan 13, 2018 | Cars & Trucks
When will UConnect be available with the iphone
Uconnect® Access for Chrysler, Dodge, FIAT , Jeep & Ram https://www.driveuconnect.com ... the next generation of in-vehicle connectivity system for Chrysler, Dodge, FIAT, Jeep & Ram ... There are several Uconnect ® Systems available ... iPhone and ...
  • Services and Apps from Uconnect® Access www.driveuconnect.com/features/uconnect_access UCONNECT ® Access. Learn how Uconnect ... Check out the features and applications that are available on your Uconnect ... iPhone and iPod are registered trademarks ...
  • Uconnect Access on the App Store - iTunes - Apple https://itunes.apple.com/us/app/uconnect-access/id550295151?mt=8
    • 1.7/5
    • 106 REVIEWS
    • FREE
    • LIFESTYLE
    2016-02-25 · Download Uconnect Access and enjoy it on your iPhone, iPad, and ... and if/when they will be available inside ... a compatible Uconnect 8.4 or ...
  • Iphone and Uconnect ' Apple Support Communities discussions.apple.com > iPhone > Using iPhone
    • 6 POSTS
    • FIRST POST: 2011-01-19
    2011-11-16 · ... Just an update to everyone experiencing connection issues with the iPhone 4 and the Chrysler Uconnect handsfree ... when it became available a couple ...
  • Set Up Your Phone for Voice Texting ' Uconnect ... - YouTube www.youtube.com/watch?v=R8SaEXTJiTE
    • BY UCONNECT®
    • 3 MIN
    • 50K VIEWS
    2013-12-23 · Video embedded · We'll show you how to set up your phone for Voice Texting† once ... ††Uconnect® Access is available only on equipped ... iPhone uConnect ...
    • 1.7/5
    • 106 REVIEWS
    • FREE
    • LIFESTYLE
    • 6 POSTS
    • BY UCONNECT®
    • 3 MIN
    • 50K VIEWS
  • May 14, 2016 | 2015 Jeep Cherokee
    How to connect my phone to my car system?
    Not all Chrysler products have uconnect; it may show the button on the radio, but if the uconnect system isn't installed you get the error you're getting; My Dodge Nitro is the same. You can buy the uconnect from the dealer or off of eBay (they run about $300, plus it has to be installed) Details about Dodge Chrysler Jeep Ram Hands Free Uconnect Kit OEM MOPAR
    May 24, 2015 | 2010 Chrysler 300 Touring
    My uconnect stop working. How do I fix it?
    Try to turn off and on your Bluetooth on your phone, uconnect might not connect your phone automatically if it's not your favourite. You can see on your settings on uconnect. If that doesn't help, take it to the dealer, it might need a quick update. Good luck
    Jan 13, 2015 | 2006 Jeep Grand Cherokee
    I have a Samsung SGH-c417 cellphone and a 2011 Jeep Grand Cherokee Laredo with Uconnect. What is the pin number to pair the bluetooth with the UConnect?
    If your UConnect system is Mopar's, the passkey is hardcoded to '0000' (four zeros). Nevertheless, if it is factory mounted (i.e. the one which comes mounted in the internal mirror), you will be prompted to choose any four-digit number you can think of (e.g. the same '0000'), provided that you enter that same number on your phone when pairing them with each other.
    For further instructions, please, take a look at this page, select your car's year and model, click on the 'OWNER SUPPORT' tab and select the UConnect system present in your car.
    Hope you are able to sort your problems out soon.
    Regards, Carlos
    Nov 07, 2010 | Samsung Cell Phones
    My 2006 Jeep Grand Cherokee uconnect will provide prompts-voice or otherwise so I cannot connect my compatible Samsung Phone. My phone shows Uconnect on screen but when I do search on my phone it fails to...
    check jeep.com/uconnect just to make sure the model is ok. Sometime your cell phone provider can update the software to make it work better with the device.
    Oct 28, 2009 | 2006 Jeep Grand Cherokee
    My 2005 jeep grand cherokee limited uconnect on the rearview mirror dosent work, wondering what i can check to fix this
    9 time out of 10 it is the phone not the Uconnect. Try to pair a different phone on the device then see what happens.
    Oct 25, 2009 | 2006 Jeep Grand Cherokee
    Uconnect has stopped working completely. will not activiate.
    when i press the voice recognition button or the the phone button on my steering nothing works not even sound
    May 07, 2009 | 2006 Jeep Grand Cherokee
    UConnect dead - everything else OK...
    unplug the battery and wait a few min, this will reset the computer and the u conect will work...
    Apr 25, 2009 | 2005 Jeep Grand Cherokee
    Computers & Internet Logo
    118 people viewed this question
    Top Momentum Development Computers & Internet Experts
    Alun Cox
    David Payne
    David Payne
    Are you a Momentum Development Computer and Internet Expert? Answer questions, earn points and help others
