Question about Koss KS3102 System
KOSS3102 parts Can some one kindly help me to know the values of the following components in the power unit of KOSS 3102? R517; R518; R519; thanks
R517 is 10K, R518 (closest to C509) is 100 ohm, R519 (next to R518, but further from C509)is 10 ohm. Hope this helps
Posted on Jul 01, 2007
    Genius:
  • 1,074 Answers
Contact www.samsphotofact.com or repairworld .com they might have schematic for your system.good luck
Posted on Apr 24, 2007
How to tell if a hard drive needs replacing on a samsung r519
1. If you have blue screen give us the exception code (0x000000) 2. How did you get to this point? 3. What is the condition of you install disk? Windows setup could just be messing up because the windows disk is damaged. Find an OEM copy of windows and set it up to boot from flash drive or external drive (CDs at prone to damage if you want a reliable windows install only use optical media if its in pristine condition.)
Jul 28, 2013 | Samsung R517 R518 R519 R522 Laptop Lcd Led...
My samsung r519 laptop is not charging i have bought a new charger dont know why not charging could it be the battery
the most likly suspect is the socket in the laptop, after some time they get warn and the connections on the motherboard come loose if you take it to a pc repair centrue for a fee they can disassemble the laptop and re solder the socket to the board.
Jun 04, 2012 | Samsung R517 R518 R519 R522 Laptop Lcd Led...
R517 please give value, thank you model # PT-53TW53G D BOARD
R517 is a 10K ohm 1/4 watt carbon resistor part number ERDS2TJ103T
Jul 23, 2011 | Panasonic PT-53TW53 53" Rear Projection...
I hooked up the component cable and I got a lot of green in the picture, when I use the s-video cable I get an perfect picture. I have an koss 3102 system.
Component cables are color-coded. Did you put them in correctly. One of them could be bad. Try rotating them functionally to see if the symptom changes.
Apr 01, 2010 | Koss KS3102 System
Audio
all KOSS unit i encountered are power amp ICs problem, might be yours. usually what comes first dead is the subwoofer channel. try, take that IC off first, and if it doesnt work, look for 10ohm resistor along the supply line going to the IC. to know where to find the supply pins, download the IC specs on the web such as http://alldatasheet.com/. be careful when removing the IC, this is not an easy job as I handled it. The IC is under the heatsink. once you found the bad IC, the unit will on except that channel you have pulled the part off. its a surface mount IC, if your not use to solder components such as 0402 sizes, i would suggest to have it repaired on technician. hope this help.
Jun 18, 2008 | Koss KS4102 System
R517 Burnt D" board
you will need the flyback as thats way to low. The HV splitter will only direct the HV to each of the CRTs it doesnt change or regulate the HV in any way just directs (splits) it. Let me know if you need any more assistance.
May 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Components value
This Component is red-red-black = 22ohms. Its of the same value as the R515A.
Jul 12, 2007 | Koss KS3102 System
Koss KS3102 System Logo
65 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
