You would need to pull it out of the track that is around the door panel itself and replace it with the new gasket. You may have up to 4 screws or clamps to help keep something like this in place. Make sure to keep the door cracked to help let water evaporate and not grow mold. Also, as in most Owner's Manuals, you are to clean it with bleach or vinegar to help prevent mold. Once mold grows, you can kill the bacteria from spreading, but mold stains and will always look like it is dirty.
SOURCE: mold build up around rubber in washer drum. Can
Buy affresh washer cleaner. You can order it over the internet and this should take the mold off and then if you use this regularly like the package explains it will keep the washer from molding. I use this stuff on all the front loaders that come into my shop. This stuff works great.
SOURCE: Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
SOURCE: how do I get the black mold off the rubber seal
Try this! Points 10, 11 12 particularly helpful...
http://www.letsfixit.co.uk/html/washing_machine_hints.html
SOURCE: Musty smell inside washer drum?
Here is a tip that I wrote about mold and smelly washers...
How to have a Clean Washer
http://www.fixya.com/support/r4356970-clean_washer
heatman101
SOURCE: i have a frigidaire wash
Here is a tip about how to clean your washer
heatman101
