Question about Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9160PW0 F11 Issue
My washer keeps on giving an F11 error message. If i take the top off and take all of the connectiosn of the CCU and reattach them then the machine seems to run fine for a few washes then it will start giving error messages again. Very occassionally it will give a D ll error message. Not sure if this is relevant but when the unit goes into a spin cycle the machine will shake a lot and will move its position.
Thanks for any help you can give me.
  • sjfengineer Feb 08, 2009
    I have the same problem with my washer...Service came out and said need to replace board, of course he is not sure if it is the upper or lower. In any case the repair will cost more than the machine is worth.. Accorcding the the price quotes he has given me.
    Never Again will I purchase a Whirlpool...
    Steve From CT
  • dcprime99 Feb 08, 2009
    are washer is about 4 yars old always does the f 11 code had a guy come out said he could start replacing parts but didnt know when it would stop said there are two control boards and its possible its the motor as well I am just happy that I paid extra to get an upgraded piece of **** good luck
    President:
  • Whirlpool Master
  • 2,651 Answers
Not related to shake, issue, but hte f111 and dl issue def sounds as if the connection between the 2 has been compromisdd, in my experience it has been a faulty CCU, losing communitcationsd with the door latch thus the f11
Posted on Dec 28, 2008
What might be causing the intermittent F-11 codes on a Kenmore Smartwash front loading washer?
f11 error is communication error.most likely bad solder joints in ccu or mcu.
May 08, 2017 | Kenmore Washing Machines
Washer keeps giving a F11 error and won't reset
this is what F11 means
"F/11" Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
there's a possibility you may need to repace the motor controller(ccu) but most likely you have a bad connection between the main control(the front board) and the CCU(the board inside the washer). you need to unplug washer and get iside to check wire connections. good luck to you.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F11 washer stops mid-cycle
The F11 code means that communication between the CCU circuit board at the top of the machine and the motor control circuit board at the bottom of the machine has been lost. The problem most often found is cold solder joints on the CCU board that make and break causing the F11 code and sometimes an FdL code. To fix this you need to remove the CCU circuit board at the top of the machine and have the larger solder points of the relays and the spade connectors resoldered. If your not to handy with soldering you could just print out this response and a good appliance repair shop should be able to help you out. Good Luck.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We keep getting an f11 error during wash cycle. we un pluggged it, and tried canceling cycle and re started
The F11 code says there's no communication between the main circuit board (CCU) and the motor or motor control board. The problem is most often in the CCU board. There are cold solder joints on the board where the relays and spade connectors are supposed to be connected to the board. Often times the vibration of the machine when it's working is enough to keep the solder joints connected. You'll need to remove the CCU and have those joints I spoke about redone. The CCU is located at the top back of the machine (you'll need to remove the top cover, 3 screws in the back then slide the top back and off) The CCU is in a plastic case. remove the connections (mark them first) then take out the whole case and then remove the circuit board. If you're not to handy with a soldering gun, just print out this response and take it to a good appliance repair shop. Good luck.
Dec 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Fault code F11 keeps appearing. The washer seems to be working but within seconds of starting to wash, F11 appears.
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F11 error
Hi
Thanks for using FixYa. Error F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). This usually occurs when CCU goes bad however, to check what has gone bad you’ll need to remove the top panel of the washer and also remove the rear panel to access the drive motor & MCU. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 Code Showing
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
Courtesy:JSrock
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The water is not draining during the spin cycle. I'm getting an error message f11
F11 means there is a serial communication error. The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. Check the wire harness connectors to the MCU, the motor and the CCU. Check the drive system for any worn or failed components. Check the MCU, the CCU, the motor and the wire harness.
Nov 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
420 people viewed this question
Dan Webster
Dan Webster
Sal De
