Question about ADIC Scalar 218M DLT Tape Drive
Picker unable to unload tapes
All, I am getting a situation where the picker will grab a tape & then be unable to deliver it to either a slot or drive. The error I get when I manually attempt this task is an "EF" then "6F". In the manual it states: "The jaws are moving and expecting to see sensor feedback to know when to stop movement, but the servo processor says that the jaws have reached a limit first". My question is this: "Can this be adjusted or will this require a picker replacement?" Thanks, Bill
3 Suggested Answers
SOURCE:
  • 74 Answers
SOURCE: Empty tape drive acts as if it has a tape in it.
Sounds like you have a bad tape in you media set that is breaking your drives.
Check inside the flap of all media to make sure the tapes are OK before using any of them (yes on that library it will take ages to go through them all) but finding the bad tape/s will stop it ruining more drives.
The drives should be easy for a repair company to fix but not so easy for an end user.
I suggest sending them to www.tape-drive-repair.com a few at a time for them to fix and service for you. They are pretty good price wise and offer a long warranty on the drives too.
Posted on Aug 24, 2009
  • 24 Answers
SOURCE: ADIC Scalar 100 Picker Problem
It will probably be cheaper to replace the unit with a new LTO4 as service is very $$$ expensive.
Posted on Jan 23, 2010
Servo init failure stalled xy
Hi Edouard
This sounds like the picker has failed to complete the power on self test (POST).
This may be due to a damaged library or simply due to a tape blocking the picker movement.
POWER OFF!
Try opening the library to make sure your tapes are all properly located in the magazines and have not fallen out.
Also try gently moving the picker to see if you can locate any other obstructions. Be very careful as you obviously do not want to break the picker or anything else accidentally.
If you are in the UK and are still having trouble, click the link below and we will do what we can to help.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Feb 28, 2014 | Quantum SCALAR 50E LIBRARY LTO3HH TAPE...
Error codes: 8C0A, 8C0D
This sounds like a picker fault (rotation blocked). Remove the mags from the library.
remove the power from the library (and your watch!)
Gently feel about inside the library and remove any additional tapes floating about inside.
Try again.
If this does not work then try going to http://tape-drive-repair.com as they have spare parts and pickers that they can use to fix the library.
Sep 27, 2013 | IBM TS3100 (3573S4S) LTO-4 Tape Drive
IBM TS3200 tape Library error code 9E 09 Hi There
OK if you are in the UK then defiantly try going to http://tape-drive-repair.com/ for them to help as these can be a pain to seat the picker correctly and you might well need parts anyway.
However if you are in the US and are unable to do that:-
Dissconnect the power.
Gently raise and lower the picker by hand and again check for any obstructions.
Sometimes the picker comes off its rails or skips a gear.
You can also try raising the picker to the very top before lowering again - make sure the picker is totally level when it returns to the bottom.
This is the same unit (in effect) as the dell TS4000 so that might also give you another search term when googling the issue.
These units are great libraries but you must be very gentle with them when doing this sort of procedure as it is easy to bend and break things.
Also make sure the library is totally square in the Rack - i have one unit where the customer had one corner 1U too low in the rack but the library had still managed to be screwed into the rack. Because the library was no longer square, things started to jam and fail to pick tapes. Once square again all was well.
Sep 03, 2013 | Computers & Internet
Error elevator init
Sep 02, 2013 | IBM System Storage TS3200 Tape Library...
HP StorageWorks 1/8 Tape Autoloader SDLT 320 - tape library - Super DLT - SCSI Displayed Error! Code: A0 When you try to import or export are displayed error code 90
The library picker arm cannot move to the home position. There could be something blocking it. Try the Reset option from the Configuration menu. This is detailed in the library user guide.
Jan 11, 2011 | Quantum ValueLoader SDLT 320 Super DLT...
How do I remove a stuck tape?
Power the unit down and very carefully unscrew the cover.  The greatest care must be when taking the tape out so that you don't bend the unit.
Consider blowing it out to get rid of dust and it very likely has a problem that will require service.  My quantum px502 had a stuck tape and I took the cover off but the picker was already off track - $700 to fix that and replace a sensor.
It gets heavy use and was serviced before in the three years it has been running.
Jan 18, 2010 | Quantum DLT-V4 DLT Tape Drive
Jan 07, 2010 | ADIC Scalar 100 Ultrium Tape Drive
Tape jammed. How can it be manually ejected?
Most or all robotic librarys must have the cover removed.  There is not "automatic" way to unjam the tape picker.
Dec 29, 2009 | Exabyte Magnum20 (270022-111) Ultrium Tape...
Tape stuck in drive
The best way that I have solved this is by using the move commands from the drive, and move it from drive to any free tape slot. Also if that does not work, put a few tapes in the drive and perform the random moves test in diagnostics, that will fool the drive to move the tape.
Jan 29, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
Error on ATL M2500
most likely this is a drive issue or picker problem. did u try to power cycle the library?
Nov 19, 2007 | Quantum ATL M2500 Tape Drive
ADIC Scalar 218M DLT Tape Drive Logo
99 people viewed this question
Top ADIC Computers & Internet Experts
Alun Cox
k24674
Are you an ADIC Computer and Internet Expert? Answer questions, earn points and help others
