Question about Dryers
Whirlpool gold utra care II gas dryer does not dry
Gas ignites every minute just for a couple of seconds but then stops. Dryer does not dry at any settings. Can you please help?
  • Anonymous Mar 16, 2014
    Whirlpool dryer won't spin. Starts but stops after a couple of seconds.
  • Dryers Master
  • 8,220 Answers
That has to be a stopped up vent or a lint filled dryer. You gotta clean out the lint, open the vent.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 27, 2008
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool Gold gas stovetop ignition stuck to on
Pull the knobs off and use a hair dryer blowing down the gas valve stems to dry out the spill. They should be fine once they are dry.
Jan 01, 2010 | Whirlpool Gold GW399LXU Gas Range
My Whirlpool GOld Ultimate Care II electric dryer is not drying well any longer. It is 5 years old and a load must be run 2-3 times to get it to dry. Please help.
it could be your heating element but if you use dryer sheets take your lint trap out and see how well water will run thru it it may need to be washed in hot soapy water hope this helps
Dec 13, 2009 | LG DLG2524 Gas Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool gold ultimate care II dryer shuts off then won't start for a while.
I am assuming this is a gas dryer and it gets hot to start then gas goes off? if so this is a problem with the saftey valve coils, this website will instruct you how to replace them.
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/gascoil.php
Jun 22, 2009 | Whirlpool GGQ8831L Gas Dryer
I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Whirlpool ultimate care II gold electric dryer
the top and the front has to come off
Feb 04, 2008 | LG DLG2524 Gas Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
Marvin
Marvin
