Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Ultra Wash III Dishwasher will not drain properly
My Kenmore Ultra WAsh III Dishwasher does a good job on cleaning the dishes, but when the draining starts, the water comes out of my overflow valve on the kitchen sink. The counter gets flooded as does the cabinet below. Can't understand why this is happening. The garbage disposal drain is not clogged. Can anyone let me know what would cause this problem?
Thanks,
Curt I have the same problem, but my sink drain is fine, any thoughts or remedies?
  • spazmo1969 Jan 05, 2009
    it runs fine but just dont drain after wash
    Genius:
  • 2,120 Answers
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Posted on Jan 06, 2009
2 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: Kenmore Ultra Wash III Dishwasher will not drain properly
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Posted on Aug 26, 2008
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenomore ultra wash dishwasher will not clean dishes- water pump may be out? How do I perform self diagnostic test?
check and see if both wash arms are turning first.
does the lower arm turn but the top arm does not?
Another way to check to see if your upper wash arm is turning is to put a mug in the top rack upright. close the door and turn the dishwasher on if it fills the mug within 2 minutes you are getting proper curculation.
you press heated dry and high temp wash and toggle back and forth within 6-8 second. all the lights should light up and it will go into diagnostics.
Sep 03, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Not cleaning properly
take a good look at the two spinning washers they are easy to remove i would suspect they are clogged clean and replace.adrian,,,,
Jul 14, 2010 | Kenmore Dishwashers
Kenmore 655 Ultra Wash- dishes not getting clean and have a residue on them when done washing. Arms appear to swing freely.
Does the dishwasher drain the water properly at the end of the rinse cycle. Meaning, is there any leftover water at the bottom of the dishwasher.
Sep 01, 2009 | Kenmore Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Aug 26, 2008 | Dishwashers
Kenmore 24 in. 15932 Built-in Dishwasher Logo
766 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
