My tally 2280 is printing just fine except it is not completing the E's and F's. It just started doing this and I am not sure what to do. Any suggestions would be greatly appreciated.
It sounds like you may have a broken (or perhaps stuck) pin in the printhead. Check for missing dots in other letters also, or if printing a graphics object, again, a missing dot, consistent throughout the print.
Other possible causes of a pin not being "fired", are a small break in the ribbon cable from the printhead to the control circuit. Look for a tiny crack or break in the ribbon, especially along the edge. Also, a defect in the electronics which control the printhead pins will cause this.
If by chance the printhead is all gooped up with old ink, a pin might merely be stuck. I have taken printheads out of dot-matrix printers and soaked the pin area (area closest to the paper) in rubbing alcohol, or used Chemtronics cleaning chemicals to spray off the old sticky ink. Messy job: don't wear a clean white shirt!
Lastly, if a pin is broken, either the printhead must be replaced, or sent in for repair, assuming repair centers still exist. In years gone by, I have sent in heads, and gotten them repaired successfully.
Hi, Iam Having problem to work with tally 4.5 in xp giving the error message that insufficient dos...
(More)
Hi, Iam Having problem to work with tally 4.5 in xp giving the error message that insufficient dos files. Kindly show me the solvation
I have a tally printer that needs setting up. Can someone help with the procedure for setting up...
(More)
I have a tally printer that needs setting up. Can someone help with the procedure for setting up this printer. It is a T2280 printer
