Question about Microsoft LifeCam VX-3000 Web Camera
LIfe Cam 3000 problems with Windows live messenger 2009
Camera works fine on the PC but when I start a video call I get an error that camera is being used by another software. I have everything else turned off? I have reloaded software for camera and live messenger numerous times.
I can see others when they call me but my camera will not interact.
  • 26 more comments
  • Anonymous Dec 29, 2008
  • Anonymous Dec 30, 2008
    My Mom is having the same problem. It maybe a firewall issue.
  • delta 4 Jan 11, 2009
    I have the same problem, also under options audio and video setup states no webcam detected also right click on contact who is online with webcam, no facility to send video call
  • Anonymous Jan 11, 2009
    same problem here...with windows live messenger 8.5 the camera works great, but with 2009, i have the same problem, "camera is being used by another software".
  • Anonymous Jan 12, 2009
    Same problem
    The same
  • francesramos Jan 13, 2009
    I have the same problem.
  • Anonymous Jan 13, 2009
    I have the same exact problem, looks like a big boo boo on messenger's part :(
  • Anonymous Jan 14, 2009
    me tooo.. i have no options and it tells me another programis usin it
    I have the same problem but my camera is built into my laptop, how do you sort it ???
  • tcorr84 Jan 18, 2009
  • Anonymous Jan 18, 2009
    no vid with new version of windows live messenger
  • dkmccurt Jan 19, 2009
    I have the same problem. When I try to make a video call, I get the message "We couldn't start you camera device. Please check that your camera is not currently in use by another program and then try again."
  • billi shawl Jan 20, 2009
    samr prob :\ i tired uninstallin teh 2009 msn live buh i coulndt do tat eithr dint ahby any options or the saoftware in add or remove app :\ werid S: wat to do?
  • Anonymous Jan 22, 2009
    Im using an acer notebook with build in camera. The Live Messenger 2009 cannot use the camera. He tells me it is beeing used by another programm which isn't true. In my case i cannot access the audio and video setup either. The drivers are properly installed and the programm used to work one or two times and then quit. Obviously a programm error of Live Messenger 2009
  • Anonymous Jan 30, 2009
    Anyone got a solution..? :/
  • smarties615 Feb 06, 2009
    numerous times.
  • Anonymous Feb 06, 2009
    I'm using a Sony Vaio laptop with built-in camera with the same problem. After much searching it appeared to be a firewall problem, so I disabled that -- and it didn't help. I have gone through the audio/video set-up again and it works fine in that context, but I still can't video conference. On occasion I can video-con if the other person contacts me, but my camera doesn't show up. Sometime during the call, the system kicks us off and then the other person can't contact me by video con. Audio calling is also intermittent if initiated from the other person. I cannot initiate either video or audio conferencing.
    Didn't have this problem with the Beta version, only the production version. After spending three days on this problem I have determined that Live 2009 sucks and I'm going back to a previous version.
    Thanks for the try but cant run audio video setup in messenger 2009
  • ACB36 Feb 09, 2009
    I have the same problem I did go to tools as I have been making video calls for about 6 years now. When I try to run the audio and video set up I get the message 'we are unable to run audio and video set up'. I have tried calling with yahoo, paltalk and palbee and skype and and mns messenger, and they all work perfectly. Any ideas?
  • Anonymous Feb 22, 2009
    hi in the same boat just not working
  • Anonymous Feb 24, 2009
    can't go to video and audio set up it just says I can't run it
  • gooog100 Feb 26, 2009
    video call setup
  • Anonymous Feb 27, 2009
    same as everyone that my cam must be in use and they cannot run the video audio set up...
  • Anonymous Mar 07, 2009
    I have the same problem after download the window live messenger my webcam cannot choose show webcam.
  • annewithany2 Mar 12, 2009
    I have the same problem. It used to work fine with Windows messenger until I upgraded to the newer version of messenger. Now it doesn't work.
  • richie_powel Mar 19, 2009
    The solution given below does not appear to work for messenger. If I try and setup audio and video I just get a basic error message stating that they can't be setup - this only appears to happen with the latest release.
    Any help would be appreciate
  • prtyimp Mar 27, 2009
    I tried the fix suggested still get the same response. I reinstalled software and now I get an error saying I have no sound card. I can record a message and send it but still cant send my vid. PLEASE HELP
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Posted on Jan 31, 2009
I had the same problem...If you have McAfee, your site adviser will not allow let you to use the audio and video features. Use this website to correct this problem: http://service.mcafee.com/faqdocument.aspx?id=TS100601 it will guide you through the steps..
Posted on Aug 08, 2009
MS Live Messenger with MS Life Cam VX-5000 problem on video calls
I have experienced the same problem, and rebooting my machine seems to help every time.
Jun 20, 2009 | Microsoft Life Cam Vx-5000 Webcam
Please check that your camera is not currently in use......
Normal 0 Also send this to your family and friends so they have their computer setup properly.
To install Windows Live Messenger, double click on this site to download then install. (http://www.soft32.com/download_30.html )
v
Hope this helps. Bud
Mar 24, 2009 | Creative Labs Live! Cam Voice Webcam
I downloaded msn live messenger 2009 and have had nothing but problems with my mic. I have a HP pro camera with a built in mic. This was working fine with msn live 8.1. I have a brand new HP with Vista....
Normal 0 See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have there computer setup properly.
A. Skype Setup:
Mar 21, 2009 | Microsoft LifeCam VX-3000 Web Camera
Latest Windows live messenger won't let me use my webcam
Normal 0 See section C. Windows LiveMessenger in the info below to setup the Audio & Video.
Also send this to your familyand friends so they have there computer setup properly.
Web Camera’s have to besetup on the program they are to be used with. Just installing the camera on your computer does not set it up tobroadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able tosee and her to you.
C. Windows LiveMessenger:
Go to thissite http://download.live.com/?sku=messengerand download Windows Live Messenger.
NOTE: Your audio andvideo should work. Enjoy.
When done both the Audio and Video will function properly soyou can chat and see family or friends you are connected to.
Hopethis helps. Bud
Mar 12, 2009 | GE MiniCam Pro HO98756 Webcam
LifeCam is installed, Windows Live Messenger is downloaded. When I try to start a Video Call I get an error message that Messenger is not available. Don't know what to try. Help
try this it may help, go to google and type windows messenger download, try downloading this again and it may pick up the web cam....i had windows live messenger installed and i downloaded it again and it picked up my web cam and its the same one you have. this may help you. when i first got my web cam set up i had no voice but after tinkering with it i got voice etc...
Jan 21, 2009 | Microsoft LifeCam VX-3000 Web Camera
Windows Live Messenge Cam Error
you need to configure your cam for msn
Next go to the Menu Bar on right side, click on Action.
Jan 13, 2009 | Microsoft LifeCam NX-6000 Webcam
Webcam not working with windows live messenger beta
You are Unable to Initiate a Video Call or Video Conversation in Windows Live Messenger after Upgrading to the Latest 2009 version (build 14.0.8050.1202)
Note: This information only applies for users who have the McAfee Site Advisor.
SYMPTOMS:
When trying to initiate a Video Call or Video Conversation in Windows Live Messenger 2009, one the following errors is encountered:
We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
"Messenger is not available right now. Please try again later. (0x8ac70202)"
"Messenger is not available right now. Please try again later. (0x8ac70013)"
When trying to run the Audio Video Setup this error is encountered:
We are unable to run the Audio Video Setup
TROUBLESHOOTING STEPS:
This issue has been determined to be caused by a compatibility problem with Windows Live Messenger 2009 and the McAfee Site Advisor. McAfee is working on a patch to address this issue, but until it becomes available, you may try the posted workaround on their website at:
Solution found at:http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!14323.entry
Dec 31, 2008 | Acer Aspire 5610-4648 Notebook
LIfe Cam VX 5000 doesnt work with Messenger/Skype
Very nice cam.You should go here and read.or contact support for this problem.RICHARDM69
Dec 24, 2008 | Microsoft LifeCam VX-3000 Web Camera
Microsoft LifeCam VX-3000 Web Camera Logo
5,334 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
