Sata drive Hi again.  I did everything you told me to do and now the pc is saying the drive is not formatted.  Does that mean it is fried?
  • PegBox60965
    PegBox60965 May 11, 2010
    We aren't seeing your problem description. Start from the beginning with a brief description of what you've done. Brief, but complete :)
  • 151 Answers
i) i dont know what happened but for this query "drive is not formatted" try this:
   right click on the drive which is saying not formatted-----> select the option format-----> follow the onscreen instructions----> u will be able to format the drive or anything and able to use the drive or anything from then.......
Thanking you
M. Sridhar
Posted on Dec 29, 2008
Sata drive is not detected
Feb 09, 2014 | HP 5188-5622 NODUS-M3 GL8E SYSTEM BOARD
Computer says samsung sata spinpoint HM080JI must be formatted???
Try this drive attached to a different PC (if possible) Also you could try another USB cable if you have one suitable. DO NOT FORMAT IT as you will loose your data.
Oct 05, 2017 | Samsung SpinPoint M40 (HM080JI) 80 GB Hard...
Missing NTLDR file.
To repair missing orcorrupted system file/s, please click on this link and follow my instructions :-
May 22, 2011 | ASUS P5GZ-MX Motherboard
The original hard drive on my Dell Dimension 5150 has fried, and I bought a new one and installed windows on it again. Is it possible for me to retrieve the files on the other hard drive with just the...
If your drive is fried, then file recovery may not be possible.
If you are using a SATA hard drive that uses the thin cable with a small connection at the ends, you will also need to connect a power cable as well.
you should be able to hook up your old hard drive into your PC if you have a second SATA cable and a spare SATA power connection.
Splitters are availible at most PC shops, and should not cost very much.
Once again, if your drive is completely fried or burnt out, file recovery may not be possible.
Aug 07, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
ST3250824AS Drive unreadable
to recover ur data, try using a SATA to USB cable.. it will work as a flashdrive.. then format ur HDD again after getting the data u want.
Sep 15, 2008 | Seagate (ST3250824AS) 250 GB Hard Drive
Auto format new hard drive in new custom pc
If you mean boot from cd with xp pro during setup you will have the opportunity to format drive either fat32 or ntfs use ntfs
I have never done it but if you can do it partition your hard drive so that you can save personal file and programs on second partition then if you have to format drive again your files on second partition will not be lost
Aug 04, 2008 | PC Chips (M925G) Motherboard
Bad SATA data cable connector or drive?
Hi miss, is you're new SATA being seen in you're bios?
To check this. At boot up press the Delete key every two seconds until the bios main menu loads.
You should see the new SATA listed here. If you do not see you're new drive listed than shut down the PC & unplug the power cord. Remove the data cable & clean it with a cotton swab & some house hold alcohol. (no dripping). Wipe off both ends of
the data cable & the drive's connector. ( Allow time to dry).
Re-connect every thing & again check you're bios. If you're drive is listed than you can use you're current windows to format the drive. I gather you're current windows is running correctly.
If you get a error message from windows during format, do not worry, yet!
I suggest you download the drive's Mfg's software tools & use this to test & setup the SATA drive. Locate the white sticker on the new SATA drive. There you'll find the model number & serial number. Write the drives information down on paprer for later. You can register you're SATA drive later at the Mfg's site.
Most Mfg's have bootable software for a floppy disk & the same to creat a bootable CD-ROM disk so you can setup & test you're new drive which is what I am suggesting you do. You will need to disconnect you're other SATA drives while using the bootable software. (Just unplug their data cable). No need to unplug the power to the drive - (s).
I am sure you will be able to setup and test you're new drive. Once finished, reconnect everything. Double check everything before closing up the case. Boot you're system. Windows should see you're new drive.
Good Luck!
If I can be of more service, just ask.
Apr 15, 2008 | ASUS A8N-SLI Motherboard
Windows installing problem in compaqv6409tu laptop
you have to go to BIOS settings and check your sata hard drive setting. To get into BIOS you have to press Delete button(normaly) when you start your PC.
Dec 09, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
