Question about IOGear MiniView GCS62 2-port KVM Switch
Problems with 2 Port KVM Switch with Built-In KVM Cables
I just purchased this item and I have connected it to both CPU's which need to be functional for my daily use. My primary CPU is functional, however, when I try to toggle back and forth between the 2 CPU's, I receive a this pop-up on a black screen: "Message: No Signal". I have checked all the wires between the 2 CPU's and they all appear to be intact and correct. Both CPU's are receiving power. Help!
  • S0nshine Jun 12, 2008
    Have the same problem. I can get a temporary fix by powering off the monitor and repowering it up. Also make sure both computers are set up for the same resolution and refresh rates. I think IOGear has a firmwear problem which they have not yet acknowledged.
  • 624 Answers
The monitor is not detecting the video signal from your computer. Assuming both of your computer video cards have been tested and really work I would try the following: Try switching the cable sets that connect the PCs to the switch. If the problem follows the cable set then it?s likely the cause. If not then try switching the cables that plug into the switch so that PC#1 is now connected to the port where PC#2 originally was and vice versa. Again if the problem stays at the same position then I would suspect a defective switchbox. If it doesn?t then you probably have an issue with one of your PCs video cards. I know this is two months late but perhaps but hope this helps you or someone else researching a similar problem.
Posted on Jul 15, 2007
SOURCE:
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Jun 13, 2014 | Acer 22" X223w LCD Monitor
HOW TO CONNECT
Pretty straight forward. The cables that are attached to the KVM go to the 2 computers. The monitor, keyboard, and mouse cables connect to the KVM box.
If you have problems, let me know.
May 12, 2011 | IOGear GCS632U 2-port KVM Switch
Firmware for starview5 b0x usb11
<P>There doesn't appear to be any drivers available, per the manufacturer's website:</P><P><A href="http://www.startech.com/item-download/SV211K-2-Port-PS2-StarView-KVM-Switch-Kit-with-Cables.aspx">http://www.startech.com/item-download/SV211K-2-Port-PS2-StarView-KVM-Switch-Kit-with-Cables.aspx</A></P><P>&nbsp;</P><P>There is also a link for the documentation, if required.</P><P>&nbsp;</P><P>If I've helped with your request please give me the appropriate 'thumbs up'.&nbsp; Thanks and good luck!</P><P>&nbsp;</P><P>&nbsp;</P>
Aug 27, 2010 | StarTech.com StarView SV211K 2-port KVM...
I have a d-link kvm-121 connected with 2 pc desktop when both pc is on 1 of the pc will see the shadow of another pc and then i tried to plug off the vga cable of one of the pc there are no more shadow....
The D-Link 2-port PS/2 KVM Switch with Audio Support(KVM-121) allows you to .... docking station and a Dell desktop, using a logitech PS/2 mouse and keyboard. ... as it easily allows me to connect another computer when I'm troubleshooting problems. ... See the nine (9) Hot Keys on page 9 of the superbly written and ...
www.amazon.com › ... › Cables & InterconnectsKVM Switches - Cached - Similar
Jun 30, 2010 | D-Link KVM-121 2-port KVM Switch
I just purchased an iogear GCS1742 2 port kvm Switch. The keyboard is the only piece of hardware that will not work. I have two cpu systems and one monitor. The keyboard has a PS2 connector with a usb...
Bill,
Due to the keyboard emulation that the GCS1742 uses it may not work with a PS/2 to USB adapter. If possible try using the KVM with a basic USB wired keyboard. This will tell you if the KVM is in working condition or if there is a problem with the actual KVM. If the KVM does not function correctly with a basic USB wired keyboard then I would think there is a problem with the KVM.
May 20, 2010 | IOGear GCS1742 2-port KVM Switch
Euromax code box for virgin midia
Check that you are getting power to your StarView SV211K 2-port KVM switch. Try disconnecting the power, and then reconnect it, to "reset" the KVM. Check all the cables from port #1 on the KVM to computer #1. Check all the cables from port #2 on the KVM to computer #2.
Check all the cables from your Keyboard/Video/Mouse to the KVM.
If you still have a problem, disconnect everything from the KVM,
and connect the Keyboard/Video/Mouse directly to computer #1,
to ensure that it works *without* involving the KVM.
Oct 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Laptop will not connect properly
If possible directly connect the KVM cables to the laptop computer. Try to avoid connecting the KVM cables to a docking station. Also if your KVM has manual port selection buttons on the front of the KVM try holding that button for about five seconds when switching ports.
Jun 02, 2009 | IOGear MiniView III GCS1712 2-port KVM...
I have recently bought a KVM switch off ebay and have connected the two computers I needed to, upto the switch. The first time round the switch didnt work. To check the cables I shut down the...
Depending on the KVM (Brand, Model etc) there should also be a hot key sequence that will allow you to switch between the PC's. See if the hot key sequence works.
Also, is this a PS/2 KVM or USB ? In some cases with USB adapters you have to let the computer start up while it is set to that port. And if it is USB, does it also have a PS/2 connector? If it does, you want to use one or the other, not both. That can cause it to malfunction.
Jul 25, 2008 | Computers & Internet
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Cannot switch between PC's
Typically, the KVM indicator light will only light up on the connection that is currently active. The indicator light will switch to another connection when that connection becomes active. First I would make sure that all the mouse and keyboard connections are secure. I have seen where these sometimes pop out, and thus some componenty will not work. I would then make sure that all the computers are fully powered on. The KVM will not allow you to switch to a device if it is not powered on. The KVM may indicate that a connection is down by a blinking light if you switch to a port and the connection is not up. It sounds that you have atleast one good set of cables. I would confirm that the other sets of cables are good as well. Do this by swapping the other cables with the one port that you know you have working. Finally, with a set of good working cables, swap them over to the other ports on the KVM switch. Although it may be improbable, you may have a bad KVM. AS always, I would review the product manual here: http://web.belkin.com/support/download/files/P74711ea_F1DJ10x_man.pdf And, since this is a new product, you will also be entitled to free tech support from Belkin: http://web.belkin.com/support/phonenumbers.asp?pge=bro 1-800-2BELKIN x2263
Sep 03, 2006 | Belkin (F1DJ104P-B) 4-port KVM Switch
IOGear MiniView GCS62 2-port KVM Switch Logo
265 people viewed this question
Top IOGear Computers & Internet Experts
Damen Wong
Damen Wong
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
