Question about Fellowes (R) OD1500C High-Performance Personal Confetti-Cut Shredder
"Clunking" while blades run
When I turn on the machine, the blades spin, but there is a "clunking" - both sound and feel. It jams on even 1 sheet of paper. Seems like a gear is stripped.
Have hade the machine for several years, but not a lot of use.
I am thinking of taking apart the head, but don't know where to get a manual or parts.
Any thoughts?
5 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: Where can I get new blades?
usually these plastic pieces break from the machine jamming you really should call Fellowes customer service at 1-800-945-4545 and speak with them. They may be able to resolve your problem with a little more information on your unit.
Posted on Mar 21, 2008
  • 215 Answers
SOURCE: SHREDDER STOPS (RED LIGHT) VERY FREQUENTLY
there are what is called strippers that ride in between the teeth to keep paper from building up. they are plastic and can break after awhile. sounds like you have some of the stripper combs broken.
razors
Posted on Feb 27, 2009
SOURCE: OD700C Fellowes Shredder blades don't turn
There is a screw hidden under one of the stick on labels. Remove that and the top comes just fine. I got it torn apart, completely cleaned of debris but the rollers still don't turn. I noticed an electrical arc when the switch is pressed so the unit is toast.
Posted on Mar 05, 2010
Testimonial: "Thanks. I found the hidden screw and was able to get inside. I know what's wrong with it now and hope to get it fixed. "
  • 99 Answers
SOURCE: Fellowes Powershredder, making clunking noise and ceases to shred
2 probably causes
to check this 1st unplug the machine
now take the top off ,there are 2 screws underneath the front edge of the cover assessable when the door is open, and 2 on the back you will want to back the shreddr up to a table when you take off the top (the sensors and switches are all still connected so this takes the stress off of the wires)
now you will need to remove the blade guards there are screws at the left and right ends of the guards,
once these are removed you should have a pretty good view of the blades, look for any visible obstruction (part of a binder clip or paper clip or metal closure from an envelope for example)
if this wasn't the cause try this
on the side of the blades there is a fan wheel that is connected to the motor. When you turn the fan with your hand you can manually turn the blades, typically you will be able to turn it to a given point and then it will be increasingly hard to turn, you might also notice that the bar on the outer edge of the blades begins to bend at this point. These bars seem to break under fairly low stress and having one break will also produce the symptoms you described. replacing one of those is a costly repair, (cost is largely because it is very time consuming,)
Posted on Oct 30, 2011
I was mowing the lawn, and I ran over a dirt *****. Now the engine will not start. It also sounds like something is loose inside. I hear a few clunking sounds when I pull the cord. Do I need to take...
Yoy can try tightening the blade bolt. i know it sounds funny but if the blade bolt is loose (or even alittle loose) the blade balance throws off the engine balance and can cause it to
1 not start
2 make loud clunking noises when trying to start
3 make a real racket if it does start
try flipping the lawn mower over and just tighten the bolt that holds the blade in place.
That should fix your problem.
Please dont forget to rate my answers
Thank you
Jun 17, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Clunking noise and drum gets stuck
It sounds like your washer needs an overhaul . A new tub and bearings it's a big job with a big price tag.
Jul 02, 2010 | Hotpoint WMA32 Front Load Washer
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Noisy dryer
Don't turn the tub to much this may make the belt run off track . If the machine makes a rumble at the beginning and at the end or when u stop the machine and restart it it is probably the blower wheel,it is made of plastic ans wears out on the motor shaft.
Apr 05, 2007 | Maytag LSE7806A Top Load Stacked...
Fellowes (R) OD1500C High-Performance Personal Confetti-Cut Shredder Logo
52 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
