Question about Maytag MED9700S Electric Dryer
Maytag dryer med9700sq0 has no heat
The thermo limit and coils has continuity. still no heat
Amigaman
  • 248 Answers
SOURCE: Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Posted on Nov 11, 2007
  • 3 Answers
SOURCE: Won't Heat -Maytag Gas Dryer Model MD-4 Intellidryer
Once I paid my gas bill--mine started working normally again.
Posted on Feb 02, 2008
SOURCE: maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Posted on Jun 12, 2008
milten1
  • 1304 Answers
SOURCE: Replacing a heating element on Maytag Electric Dryer
Hank,
if you have all those parts , i would indeed replace them all. it will allow your entire heating circuit to strat fresh
just ensure all your paddle connections are tight
but check your heater for continuity too
Posted on Oct 21, 2009
Testimonial: "Thanks, I'll replace everything! "
heatman101
  • 43501 Answers
SOURCE: Maytag SE1000 Series 07 dryer wont heat
You need to have 220-240 or so volta ACROSS the two terminals on the element...the 125 can feed across and can be the same leg on both sides...
Check out this tip also..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 23, 2010
Why doesn't my Maytag dryer model LDE712 heat. All things related to check have continuity.
Sometimes you have to disconnect elements of the heating system to check continuity ('element's' as in 'parts of').
Can only be 4 things
Element
high limit thermostat
high limit cut out
mainboard/switch
Feb 05, 2016 | Maytag Dryers
Maytag Epic Dryer Model MED9700SQ0, everything lights up, power is on, but drum will not turn and no heat.
Can you tell if the motor comes on? If it does, then it could be a broken belt.
Sep 01, 2012 | Dryers
Maytag mod. #med5700tq0 elec. dryer runs, inconsistent heat, high heat two days ago, little heat a few hours ago, some heat an hour ago, no heat now. Where is the best place to start?
It sounds clogged up to me. Take the exhaust hose off the wall and try it first. Another thing that happens with Maytags is that the motor shaft will **** out the center of the plastic blower and even though the motor is turning, little or no air is moving through the machine, so the high limit thermo turns the heat off
Oct 18, 2011 | Maytag MED5700TQ Electric Dryer
I have a 70 series kenmore dryer bought it from a used appliance guy cant find him now it worked find for a month now it doesnt heat up! been lookin online seems its most likely to be the thermo fuse or...
The thermo fuse will not cause your problem. If the fuse is bad it will cut the dryer off compleatly.
There are two limit switches on the heater can and the heating element. If you have an ohmmeter you can test for continuity across the element and the limit switches. If one of the limits is open replace both limit switches and if the element is oepn replace the element.
This page will help more http://www.appliance-repair-it.com/Whirlpool-dryer.html
If you don't know how to use an ohmmeter this page will help
http://www.appliance-repair-it.com/ohmmeter.html
Sep 24, 2010 | Kenmore 62602 Electric Dryer
My Maytag dryer does not heat. The ignitor glows hot, and the coils engage (click) which lets the gas ignite, but goes out after about 10 sec. So I figured it to be the thermo fuse at the burner,...
are you sure the vent is open and not lugger? if it can't flow then it may be overheating and that will turn it off. check the vent and inside the dryer as there may be a blockage inside it as well.
Dec 02, 2017 | Maytag Neptune MDG5500AW Gas Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
My GE DHDSR46EE1WW Dryers heating coil won't shut off...ever!
I think your heating coil may have broken loose or sagged down so that it may be shorting itself against the shroud. The thermal fuse would not allow the dryer to heat at all, and a hi limit error would cause the thermal fuse to blow.
Jun 14, 2009 | Dryers
Maytag Dryer working but not heating up.
possible air flow problem,, check exhaust hose and sure not clogged up needs air flow, if long dry times repl/ coils/ only on gas models /if electric./ repl/ hi limit thermostat,// and safety thermostat ,,u need 240 volts 120 to turn on dryer and another 120 to heat ......
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Maytag MED9700S Electric Dryer Logo
173 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
