Question about Frigidaire ATF6000ES Front Load Washer
Drum/frigidaire washer I am looking for the spider arm and shaft on the drum of my frigidaire front load washer. I would like to buy separate because drum is fine.
  • makabett3 Dec 28, 2008
    model number fwt445ges2 frigidaire front load washer/ would like to know where I can purchase spider arm/shaft so we can replace it ourselves. We put new drum in last year, nothing wrong with drum but can't find where to purchase spider arm/shaft without having to buy whole drum again. Any suggestions on where we can purchase parts?
  • Anonymous Dec 28, 2008
    i have the same problem please let me know where i can get that part 410-913-0061 thanks alot chris
  • 640 Answers
Wow thats a long hard job ,,overhaul....the part your looking for is the spin tube surport,,you have to take the hold drum out than seperate the front tub from the back bearing tub,,and pull wash basket out though front..,,also if you had a leak or surport broke and is making noise.. change back bearing tub too.i recommend a professional technician...but if you want to do it your self ..post question how to change wash basket,,glad to help
Posted on Dec 27, 2008
  • onthethejob1
    onthethejob1 Dec 28, 2008
    if this is a stainless steel tub,,it has a life time warranty..look in the last page of your owners maneul..or aleast 10 to 20 years..dont purchase order from manual
I have a LG wm2277hw washing machine. the drum will spin a little and then make a scaping sound like friction. The drum has a lot of play in it. Is there a hard plastic washer or shim that wears out. The...
The symptoms that you describe sound like the spider or support arms of your washer has failed. It the part that holds the wash drum true in the plastic tub. It's a rather difficult job to replace the spider since the washer has to be taken apart to get to the spider. Fortunately, LG does sell the spider, instead of making you buy a new spider and drum. You may need to also replace the plastic tub parts if they are too damaged to be reused. Get a few estimates before deciding whether to repair or replace.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
My LG M#WM2277HB wont turn the drum. It started making bearing failure type noises a couple loads ago. I just pulled it out , removed the top/back and started it. the motor rotates cw and ccw but the drum...
Oh s***! If the motor turns but the drum does not, the drive shaft has broken loose from the three arms which attach it to the drum. (the part is called the "spider") To repair, remove bolt on end of shaft at center of motor. You may have to cut it with an angle grinder, but don't worry about that, because the shaft has to be replaced anyway. Remove motor rotor and stator. Remove washer front, drain hose, fill hose, shock absorbers, support springs, all wires attached to outer drum, and eventually the entire outer drum. Remove bolts between front and back halves of outer tub to allow removal of inner drum. Remove 6 bolts holding 3 arms of spider to back of inner drum. Re-assemble with new spider and new bolt for end of shaft. If you can do it in under two hours, give yourself a big pat on the back. This is about a 8.5 on a 1 - 10 difficulty scale for washer repair. Good luck Mike.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
My frigidaire gltr1670a washer is making a banging noise when on the spin cycle. I took the bottom cover off and watched the drum it doesn't seem to be from the outside of the drum cover it sounds like its...
It sounds like the spider arm supports in your washer has failed. The spider arms hold the stainless steel wash drum to the axle. You need to stop using the machine immediately since the wash drum is flopping around the plastic tub. It is an expensive fix. The replacement drum/spider can cost over $300 with shipping. Get a few estimates before deciding whether to repair or replace. Sorry.
Dec 09, 2010 | Frigidaire GLTR1670A Front Load Washer
During the spin cycle there is a very loud knocking noise,
Could be the spider arms are broken. You can confirm this by turning the tub by hand, if you hear any kind of thumping sound as you turn the tub, then the spider is broken. The spider is the support arms that hold the wash tub to the drive shaft. It's very expensive to repair.
If there is no thumping sound when you turn the drum, it could be that one of the supports or spring is broken. Hope this helps.
Jul 23, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Loud banging noise looks like the drum is off set and it damaged the rubber in the front
If the inner wash drum is sagging when it is empty, it probally means that the support arms that hold the drum has failed. If you turn the drum by hand and if you hear any kind of banging noise or the drum wobbles more that a fraction of an inch, then the support or spider arms are broken.
You can't buy the spider arms seperately and must buy a drum and spider as one unit. The cost to repair would be in the hundereds. See the following link to judge for yourself if you want to fix it yourself or have it fixed. http://www.fixya.com/support/t4267953-spiderarm
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer loud noise and drum loose but not dropped
Spider arms attached to stainless steel drum inside of tub have probably broken. This is a known problem with Frigidaire front loading washing machines. The stainless steel drum has a 25 year warranty but this does not include the spider arms. You cannot buy the spider arms separately, you have to buy the unit as one. The drum cost about $250.00 and probably about $300.00 in labor to install. You can do it yourself but it is pretty involved. Good Luck!
Jan 02, 2009 | Frigidaire GLTR1670A Front Load Washer
Frigidaire frontload washer
you dont need to buy the shaft, "spider".it has a lifetime warranty on the inner tub and should be replaced by frig. what you need is the entire tub as the shaft is not available seperately. if you cant get this under warranty then i would suggest buying a new unit as the outertub and bearings are what is worn causing your noise in spin. you may have to pay a warranty dealer to get the tub covered, but the whole job is very labor intensive and most people cant do it, even if you are good with tools. call frigidaire and see if they will cover the repairs first.
Dec 28, 2008 | Washing Machines
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire front load washer model GLTF1670ASO
Check the shocks on the bottom of the drum. I had the same problem and had to replace the shocks because they were broken in half.
Mar 02, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
369 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
