Numlock not turning off...some of the letters & numbers not functioning properly (eg. A, 1 & keys where the numlock is not working)
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders. Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
SOURCE: Toshiba Satellite A105 number pad doesn't work
u may want to check wether the num lock key is on or off its on u cna type nos
SOURCE: toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
SOURCE: When I type letter keys, numbers come up with the letters
check your keyboard: T and 5 are relatively close to each other. Try to clean the area under keyboard buttons especially these two buttons. may be it can help you.
SOURCE: how to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
