Screen going black on CTL pc monitor
I just got a refurbished CTL 171lx monitor for my HP pavillion pc w/ Vista. It worked fine for the first couple hours, but now the screen goes black for no appearent reason. I can get the picture back for 2 seconds at a time by turning the monitor off & on. Sometimes the screen will go black then come back on several times on it's own. Disconnecting the monitor for several hours & hooking it back up will work for a few hours & then the problem will start again. Thinking it was a driver issue I located & downloaded what was supposed to be the driver, but it was only the manual. I also went through the troubleshooting instructions with no luck. I'm lost! Is the monitor defective?
  • ntech4 Apr 03, 2009
    my lcd monitor blinking for a second only when i turn it on, after that geting black nd no any vedio signal. pls let me know how to repair it.
  • 4 Answers
SOURCE: monitor keeps going blank at start up
This looks to be a power supply fault - the inverters for the backlights are built into the power supply (Delta Electronics, model no. ADP-40AF).
Posted on Dec 11, 2007
Sunil Panem
  • 80 Answers
SOURCE: HP Pavilion - the monitor flashes off and on
Pls uninstall the video card drivers and reinstall them.
Also pls look for any graphics driver updates from the manufacturer.
Also pls check if the cable from the power supply for the graphics is connected on the motherboard.
Pls check with another monitor if it is doing the same thing.
If the same happens with another monitor, then it is an issue with the video card..
Posted on Jan 30, 2008
kjanx
  • 194 Answers
SOURCE: MAG Innovision LT1919WDb flat screen goes black
the vga controller is out.
i have one apart now on my bench. can't find a controller
Posted on Feb 02, 2008
  • 11 Answers
SOURCE: Monitor Issue: 5 seconds of picture the monitor goes black.
I had this similar problem. I found out that there was a bad 1000uf, 16V cap on the power supply board. The cap is too close to a heat sink and over heated. I bought the cap at radio shack for $2, installed it so that it is far away from the heat sink. Monitor now stays on when powered up.
These monitors are difficult to open.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated. Remove the cover plate and unscrew the push buttons. Unplug the monitor cords from the driver board. Unscrew the mounting screws from the power supply board and remove. You will need to pinch the plastic support in the middle of the board to remove. Unsolder the cap. It is located near a copper heat sink and the value will be on the cap. It will be buldged up on the top. You will see burn marks on the board surrounding the cap. Install the new cap and solder. Be careful not to solder across joints.
Reassemble and turn on. Should solve the problem
Posted on Dec 24, 2008
SOURCE: AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Posted on Nov 12, 2009
My hp pavillion goes to black screen (no signal) intermittently and emit a beep tone
The video graphics card is one of the main problems with the HP line, it gets to hot causing the solder to break down. But I would test with a monitor on the video output to be sure.
Jun 26, 2012 | HP Computers & Internet
Ihave an hp pavillion laptop where the screen went black and need a solution to fix
First hook a spare monitor to the video output jack usually on the back, if picture comes up! it indicates a bad inverter board, or the backlight has stopped working, if the spare shows the same problem, it means the video graphics card is defective and normally built into the motherboard.
Mar 05, 2012 | HP Computers & Internet
Linking hp pc (windows vista) with philips lcd via a hdmi and dvi cable. When computer turned on and tv uned into hdmi channel i can view windows loading but screen goes black when it has loaded and screen...
You need to set your system to output to the port the TV is on.
If it is a laptop, there is an F key to change from LCD to LCD+VIDEO to VIDEO.
If it is a desktop you need to go into your display settings (control panel or rt clk desktop/properties or whatever system you have).
May 16, 2010 | HP Pavillion s7420n PC Desktop
My hp Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
Well are 2 reasons for this behaviour of your notebook...first it can be an issue with the graphics card installed on the motheboard or its an issue with the Monitor cable which is connected between the motherboard and the LCD.
Following are the steps that you can try to resolve the problem:
At first we need to check whether its a hardware problem or not.
1.Restart the computer and tap on the F10 key for a while which would take us to the BIOS SET UP UTILITY...
2.Now we need to wait for sometime in this screen so that we can check the status of the screen whether the screen goes dim or it remains normal..
3.If the screen remains normal for around 10 minutes then its not a problem with the cable,
4.Now we need to get back to the windows screen and try installing the graphics driver for the notebook.
Let me provide you a couple of drivers for the notebook.
I am providing you the drivers assuming Windows Vista installed on the system
if you have an ATI card installed, the install the below mentioned driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=ob-60201-1&jumpid=reg_R1002_USEN
if you have an NVIDIA card install the below mentioned driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=vc-77961-1&jumpid=reg_R1002_USEN
or you can install the drivers directly from the manufacturers website..
Hope this works.
Regards
KEN
May 10, 2010 | HP Pavilion dv4000 Notebook
My hp pavillion dv9000 turns on but the screen stays black like it isnt getting any power to it
Connect your laptop up to an external monitor. If you get a picture on the external monitor then you know that your Chip is fine. At that point You will need to replace the screen.
Dec 23, 2009 | HP Computers & Internet
Monitor says No input signal and going to sleep. Pc is on and running Vista. Hp w1907v monitor HP Pavillion slimline pc. Can you help please?
Try cleaning your RAM it should be the issue mostly 80%
You can check by rremoving the VGA cable if the system shows no signal mostly monitor should be fine
Nov 30, 2009 | HP w1907 LCD Monitor
I purchased a ctl 170lx refurbished monitor. The screen turns on for a second and then goes black. The green power switch stays on, but no picture. Any suggestions?
return the unit to seller for warranty, it need technician to reheat loss contact or replace not working components.
Jul 03, 2009 | Computers & Internet
Hp pavillion zx 5000 screen black
GO ON LINE AND TYPE THE MFG NAME, MAKE, MODEL, SCREEN WENT BLACK.
ENTER
ROD
May 12, 2009 | HP Pavilion dv6000z Notebook
Hello I have a hp pavillion a705w it wont turn on any monitors
How Would I Go About Hooking 2 Monitors Up To My a705w
Jan 18, 2009 | HP Pavilion a705w PC Desktop
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
Sep 01, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
343 people viewed this question
Alun Cox
David Payne
David Payne
