Question about Jensen MCD5112 Water Resistant CD Player
CD player -- NOT playing
CD just sits in unit (display shows icon that it is spinning, I don't know that for sure) and NO SOUND (radio works fine) ALso, CANNOT change tracks for CD . Pressing the change tracks (up or down) nothing happens. Again those buttons work in the radio mode of operation. Thank you for your response.
  • rblain May 30, 2008
    I have the same problem, brand new stereo. CD seams to read for a while then code (er-2)?????
  • boe53 Jun 12, 2008
    Hi There, I am having the same problem with the same model stero.
    Thanks
    Donnie P
    Problem Solver:
  • 19 Answers
Did you alredy clean the laser lens?
Posted on May 09, 2007
SOURCE:
I have an AKAI radio/cd/tape player combo. For about a year I had to toggle the switch around a few times just to get the radio to come on, now I cannot get any sound at all with the cd or radio
Akai used to produce quality gear. Today in common with lots of premium manufacturers the gear is less repairable and a whole lot more disposable. This is because it is less "engineered" and more designed for cost-effective assembly.
Mechanical switches and potentiometers for instance, add weight and expense to the manufacture and shipping and they wear out or get dirty and don't work - but they can be replaced or cleaned relatively easily. Soft touch controls and electronic switching is cheaper to produce and more pleasing to some buyers but when they go wrong cleaning rarely works and repairs are beyond the usual scope of the hi-fi enthusiast, meaning expensive repair-shop costs. It is worth attempting to clean the switches if there is access and you feel adventurous.
It sounds as though you have nothing to lose. There is a wide selection of switch and electrical cleaners available, some with an added lubricant for mechanical switchgear and potentiometers though for some things a cotton bud or a slip of paper dipped in methylated spirit works well.
Aug 10, 2016 | Audio Players & Recorders
My cd player spins but there is no sound
Try cleaning laser eye with glass cleaner and q-tip
Apr 13, 2016 | Audio Players & Recorders
No sound from cd player
the laser lens needs cleaned most likely, you can purchace a cleaning disk, or take the unit apart and used a eyeglasses cloth and very gently wipe the lens clean. the lens will be very small and near the motor that spins the cd. when wiping it off, wipe in one direction only. if that doesnt work then the laser has become weak or has quit working
Jan 14, 2010 | Sony CFD-E75 Cassette/CD Boombox
I have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Dec 18, 2009 | Bose Wave Radio
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Nov 16, 2008 | Eclipse CD2000 CD Player
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Feb 07, 2008 | Aiwa CDC-Z127 CD Player
Bose Lifestyle 12 Porblems
sorry mate, looks like cd 5 is damaged goods...... wheter you damaged it or not, can't say....
however, make sure. when you try to play cd, that the cd button, nearest display was pressed as just putting in a cd isn't automatically taking control of the cd function like in other cd players. ( that is to say you have to diliberately select CD mode to play cd's)
if you fancy a load of electronic messing and visits to radio shack i am sure you can repair it if broken,
or a second hand cd unit could be obtained elsewhere on line.
Jan 02, 2008 | Bose Lifestyle 12 System
Sony Net MD Walkman (MZ-N910)
had the same problem a few minutes ago!
removed the battery but it didn't help.
tried with another md, no success
tried the same md in another Mz 910, no success
then it got on my nerves and I gave the MZ n910 a little shock with my hand.
It worked, stopped spinning and started to play.
It was, I think, a spinning problem, md couldn't play properly, the little shock helped.
Apr 09, 2007 | Sony Net MD Walkman MZ-N910 Portable...
CD Player Not Working
I have the same problem with my sterio. Only occationally plays the cd, but very rarely.
Aug 03, 2006 | GE 75295 Clock Radio
Jensen MCD5112 Water Resistant CD Player Logo
373 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
