Question about Samsung LT-P1745 17 in. EDTV-Ready LCD Television
My brightness keeps resetting
I have a samsung LCD tv and i adjust the brightness levels because my tv is too dark and about 15 - 20 mins later my settings reset and my tv gets really dark... how can i fix the settings so they dont reset every 15 mins??
  • 1 more comment
  • Anonymous Feb 16, 2009
    I have the same problem.
  • Anonymous Mar 24, 2009
    i got this as a floor model and it works fine except after about an hour (im guesing) it switches to 45% brightnss. it sucks especially when youre watching something important.
  • Anonymous Mar 29, 2009
    All my settings just reset back to 45% brightness and colour after about 30 mins and is really annoying having to keep changing it..... does anyone know how to solve this???
I had the same problem....... on the actual tv u have to press and hold the volume button and menu button together for about 5 seconds and then on the screen it should say dynamic and that hopefully will sort it for u. Worked for me :)
Posted on Mar 29, 2009
    New Friend:
I had the same issue and I have an LED TV. In order to correct it you must go to user menu->system->eco solutions->energy saving and click off. If the problem persists you have to turn the eco sensor off as well. user menu->system->eco solution->eco sensor.
Posted on Jan 26, 2013
Fading brightness of sharp 20v-l70m
pls. try adjusting screen control.
Jul 04, 2013 | Sharp 25R-S100 25" TV
SAMSUNG LCD TV very bright screen
hi Elle924.
this is all i could find out.
What kind of panel do you have - a LED or CCFL one? If it's CCFL then check the inverter board. The main board might be fine (changing the brightness settings changes the signal to the inverter board) but if the inverter board is faulty somewhere then the problem you described may be caused by it
or try this forum.
Why is my tv extremely bright Solved Other Consumer Electronics
or this one might help you.
White too bright in picture on Samsung LCD TV Forums
or even this link.
SAMSUNG LCD TV very bright screen Google Search
Nov 28, 2017 | Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
42 inch toshiba\r\n tv screen
Dark picture. I adjusted brightness, but it keeps getting dark. It has vertical lines that can be seen in grey areas on the screen.
Dec 08, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
My Samsung32'' resets to default settings every 30 mins!
Hi reset the tv and put it in to home mode!!!!
Shop mod resets tv settings every 30 mins
Apr 13, 2009 | Samsung Televison & Video
Samsung Monitor 720N
check the resolution of the system make it as 600*800.
Jan 06, 2009 | Samsung SyncMaster 720N Monitor
Brightness keeps shifting on Samsung 46" 7 Series 750
I just purchased Samsung series 4 LCD TV yesterday. I had the same problem since my salesman was a kind of stupid. He set the 'Power save mode' to automatic. After fiddle with my TV for a while, I found the solution.
Just change the 'Power save mode' to off, low, normal or high. My LCD TV stopped shifting its brightness.
Jun 23, 2008 | Televison & Video
Samsung LT-P1745 17 in. EDTV-Ready LCD Television Logo
1,156 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
