Question about Brother IntelliFax-2820 Laser Fax
Print is light
I just replaced the toner cartridge with the genuine brother cartrige and the print quality did not get any better what next?
    Problem Solver:
  • 8 Answers
If you have replaced your toner and your print quality is still light, your next step is to replace your drum unit, if it has not been replaced lately. This particular drum unit has a life of roughly 12,000 pages.
Posted on Jan 03, 2009
I just changed the toner and the printer does not print.
If u have the CD of tht printer , u just delet tht printer from the Devices and printers settings. And re installed it
Aug 14, 2012 | Brother HL-2040 Laser Printer
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
Prints only on a small portion of the page
Try:
Brother strongly recommends that customers use only genuine Brother drum units and/or toner cartridges. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of third party drum units, toner cartridges or toner.
For LIGHT print continue to STEP 1.
For BLURRY, VERTICAL or HORIZONTAL LINES, SMUDGES OR DOTS continue to STEP 4.
1. Check the Toner Save setting. If this setting is programmed on, all printed documents will be light.
a. Press MENU, 1 (General setup), 6 (Ecology), 1 (Toner Save).
b. Press the UP OR DOWN ARROW key until the display reads "Toner Save: OFF".
c. Press OK.
d. Press STOP/EXIT.
e. If the setting was changed from ON to OFF print the User Settings list by pressing the REPORTS key and then 5 (User Settings).
Nov 11, 2010 | Brother MFC 7840W Printer
My printouts have a very dark haze over them.......the printed letter are fine but it looks like the print cartrige is dumping ink on my paper as it prints. It look like a bad fax copy. What is the...
Either you purchased a a bad quality remanufactured toner cartridge or your fuser film is damaged.
If there is some kind of debris in black color that is on printouts, your fuser film might be damaged. Have a printer technician replace it.
If there is no debris, only bad quality printouts, it's the toner cartridge that needs replacement.
May 31, 2010 | Brother HL-2040 Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
MFC-7420 GHOST IMAGES
sounds like a bad drumbur also can be caused by a defective fuser.
Jan 16, 2009 | HP LaserJet 1020 Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
"Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Oct 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
