Question about BenQ FP71G+ 17" LCD Monitor
No signal - out of range
Hiya i seem to have a problem with my monitor. the monitor has been installed from sometime but has been unplugged and moved now when we plug the monitor into the port t comes up not signal , so we tried swapping wires around and in the 2nd port on my tower the message reads out of range.... there is power but no signal seeing as thi monitor has worked before how could this be? please could someone help
  • 472 Answers
Start the computer.
After the ios info page/motherboard page is gone, start to press F8 a few times.
If you still get to the point that you see the Windows Logo loading screen, then press reset and try again.
If you have done it correctly, you will get to the Windows boot page.
Select Safe Mode and start Windows
Go to the video properties page by right clicking anywhere on the screen and adjust the video mode to 640x480 (or as low as it will go)
Restart the computer and see if that solves the problem.
If not, then do the same procedure, but go into system properties and unistall the video card.
Restart again, and install the drivers if needed.
Hope it helps.=)
Posted on Apr 09, 2008
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
Jan 27, 2016 | Dell Computers & Internet
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • Aug 08, 2010 | Compaq TFT8020 18.1" Flat Panel LCD...
    What does F1 indicate? My oven seems stuck on Broiler and a signal keeps flashing F1 with beeping signal. What could be wrong?
    F1 is a common failure on a lot of ge oven controllers. Although sometimes it is caused by a keypad failure. The test is to disconnect the keypad, power up the oven with the keypad unplugged ... see if you get an F1 ... may take a while ... 30 minutes or so. If you still get an F1 then the problem is with the oven control board. If so, we can repair the board for you.
    Bruce
    www.fixyourboard.com
    May 10, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
    Monitor says no input signal going in sleep mode
    TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
    Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
    Hiya ive got a 19 inch dgim monitor which gose blank with the red power light flashing any help
    hi carpinsy
    check if the signal cable is fitted snugly at the back of the monitor and then check the same at the back of the computer.if not,it seems the computer has aboot up problem.
    check the first two solutions and if it doesnt help,get back to me :)
    Feb 04, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
    I turn on my computer but my monitor says there is no signal
    hello, try to unplug the cables on your desktop, then plug it again, sometimes its loose, or sometimes the power supply on your computer is not functioning properly.
    Nov 02, 2009 | Computers & Internet
    Input signal out of range
    Did you mean "out of range". Try reloading video drivers. If that doesn't work, perhaps screen cannot use that resolution.
    Jun 28, 2009 | HP Pavilion F1523 15" LCD Monitor
    Acer monitor lcd problem
    Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
    Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
    BenQ FP71G+ 17" LCD Monitor Logo
    341 people viewed this question
    Top BenQ Computers & Internet Experts
    Steve Allison
    Steve Allison
    Tommmix
    Level 1 Expert
    Joaquim Martins
    Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
