Question about Acer TravelMate 4200 Notebook
My wireless network card needs a new driver?
Help! I can't access my wireless network. The ISP tech support says that I need a new driver, but they can't install it. Basically, my wireless card isn't receiving packets even though it's sending them. I downloaded/installed the broadcom wireless LAN driver from Acer's website, but my wireless card still isn't receiving packets.
  • Chinmay Joshi
    Chinmay Joshi May 11, 2010
    dear sir
    if u need a drvier plesae conform me yr model and device name and serial no
    Passionate:
    Visited the website for 10 consecutive days.
  • 126 Answers
I have actually experienced this before and surprisingly, it turned out to be a hardware fault with my built-in wireless device. I had to resort eventually to one of those USB plug-in wifi dongles. They cost less than ten bucks, and if you don't need the range, come in "nano" sizes that protrude less than half an inch when installed. Do disable the internal wifi device, either in device manager or better still, in the bios if using this solution.
Posted on Nov 13, 2017
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: cant find my wireless card in device manager in acer travel mate 2300
In some Acer models, there is a software switch in Start/All Programs/Acer Launch Manager. If this is missing, you need to reinstall since even with the WiFi hard switch activated, this application is required. This is so especially if a new/clean/OEM install of the OS has been done on the laptop.
In some models, there is a hard switch either at the front or at the side to activate the internal wifi (and bluetooth). Still in other, there is button on the leading edge of the computer which also serves as an indicator lamp,
Some models also have WiFI enable/disable in the BIOS/CMOS setup.
Still others have a button along with the Easy-launch strip (top) together with the those for email , bluetooth , Acer Arcade & others.
As shown above, depending on the specific model/region version of your laptop, the WifI activation can be varied.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 19, 2008
mspcrepair
  • 169 Answers
SOURCE: wireless not working
First, go to Windows security settings. I recently had a client with this exact problem, and it was her Windows firewall blocking the wireless adapter from "seeing" anything. If necessary, turn the firewall completely off to test.
Secondly, if that doesn't fix it, remove/uninstall the Wireless adapter completely from device manager. Reboot, let Windows attempt to reinstall the driver. If asked, point it to the driver files you've already installed. Reboot, and that should fix you up.
Let me know if this helps :)
Posted on Sep 29, 2008
  • 479 Answers
SOURCE: CANNOT DETECT WIRELESS NETWORKS
Please type services.msc on run option
2.Please check there will be a service named as wireless zero configuration if you are using XP otherwise the third last service in vista.
3.double clisck that and then stop after restarting the machine again go to same and start it by clicking start.
4.If then also the issue is not resolved please check with your hardware vender.
Posted on Feb 09, 2009
kd6rhd56
  • 400 Answers
SOURCE: I have a hp compaq nx 9000 notebook and am unable to connect
it sounds like somehow the WPA was turned off . Can you reenter your internal router and re-initailize the WPA setting for your laptop, if there a setting for WPA And WEP together ,check that box. Hopefully that does the job.. good luck
Posted on Jul 11, 2009
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
I cannot connect to my home wireless network provided by my new ISP, after I ended my subscription to my old ISP. Connection via old ISP was via Dial Up; connection via new ISP is via broadband. I have a...
First of all you may try to check the adapter settings on your computer.
Start>control panel>network and sharing center>adapter settings>check status of broadband(should be connected)
If not right click on broadband connetio and click on connect if still showing as disconnected
You may also check internet option settings.
open IE>tools]nternet options?>connection tab>tick on never dial a connection.
Click on LAN settings tick on automatically detect settings>ok
You may also check for the if the driver for your wireless broadand is working by checking it on device manager.
Try to check if broadband is working on the other computer.
Apr 15, 2011 | Dell Inspiron 630M Notebook
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
B52Computers
Jan 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I need the drivers for my router its the WRT54G
There are no "drivers" for routers. There is firmware. You can go to the routers setup page, and check for firmware updates.
The firmware is downloaded and installed from a wired computer connection to the router.
The linksys website is here.
Mar 25, 2010 | Linksys Wireless-G WRT54GS Router...
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
How do i turn on my wireless capability?
Are you trying to turn on wireless in a laptop, PC or the modem itself?
Modems have a specific IP address that you can get from tech support of your internet vendor.
Laptops if WIFI onboard should simply have it.
Laptops with WIFI cards need drivers and sometimes software.
PC's with WIFI card or USB WIFI often need software etc.
Once working you then need a WPA or WPE login and password to access the internet. If at home you should have that information or call your ISP.
Oct 19, 2009 | Acer Aspire 5050-3242 Notebook
I installed my linksys g pci wireless router after uninstalling at the advice of the linksys tech. I use free wireless network. The tech installed a security enabled wireless network VU1V3 and now post...
wooooh wooooh
Marcia...............Is this a small home system here. Was this an onsite tech. ISP is Internet Service Provider and not so sure that is the issue. WOW this can get confusing. Perhaps this tech can redo his work for sake of your time. An adapter does allow the ISP to see how many PCs you are using.
Sorry Marcia .................Really would be nice if Mr. Tech could reassist you on this.
Bill
Apr 24, 2008 | Computers & Internet
Wireless connection
There are a few requirements other than the laptop and the wireless card. You need to also have an Wireless AP/Router that must be connected to the modem that connects to your ISP. All your PCs must then connect to this router either using the wired/Ethernet ports or WiFi.
If such a device (WiFi AP/Router) already exists and is connected to your modem and your other PC(s) are tied up to it and can access the Internet, you need to install the drivers (in a CD that came with the wireless card) to your IBM ThinkPad. Thereafter, you need to configure your laptop's wireless networking to access the AP/router. Your AP/Router must also be configured to accept wireless clients.
Please post back with brand/model of your AP/Router.
Hope this be of initial help/idea. Pls post back how things turned out or should you need additional information.
Feb 01, 2008 | IBM ThinkPad T20 2647 Notebook
USB modem cable quandary
i am new too --may this trigger more people to help
from my limited experience
yes u need a NIC card in your pc
isp signal--->isp modem---->rj45 cable---->wireless (switch/access point/ Router--->NIC(PC)
---->wireless adapter (notebook)
----->wireless adapter(PC)
nowaday with a Gigabit Nic
u can match 802.11b 11mb/s
802.11g 54mb/s
802.11n 300mb/s
i use verizon at first with PPPoE
later Comcast cable dynamic
u need to go to web site ip address assigned by DHCPof your 3com wless router to make sure or/and clone the router so that it has same MAC addtress as your NIC of your PC before u can get CONNECTED with the Web----(u can see the green display on the upper right of the screen of the router page after u get connected) dl
Dec 25, 2007 | 3Com OfficeConnect Router
Wireless signal degredation
Disable and renable wireless card, even try unistalling the wireless card and reinstall it. update driver for wireless card. then if those fail, put pc next to router if signal still bad then card needs replaced. If your ISP didnt have you power off the router for 30 sec then do so.
Nov 18, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Acer TravelMate 4200 Notebook Logo
179 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
