Question about Proscan PS52690 52" Rear Projection Television
Have a Proscan 52in Projection tv. It always dies about three months or so after moving from one house to another. It has always been the same problem and part. Ordered the part online and replaced it myself. It was the HV Block. Tv now powers up but the blue seems to be out of focus and blurring. Most notably seen around white abjects. Is there a focus that needs to be adjusted or is there something else that might be wrong. The general tips online say it can be focused with three pots marked screen voltage and focus but can't seem to find them. Can you help?
5 Suggested Answers
SOURCE: ProScan 60 " Rear projection T.V..
power supply,safety protection has kicked in
Posted on Aug 24, 2008
SOURCE: ProScan Projection TV PS60690 shuts off
replace the small 5G5A125V fuse in the back where the power cord connects the to chip
Posted on Sep 02, 2008
  • 8 Answers
SOURCE: main fuse keeps blowing on my Proscan 60690
check the voltage reg.
Posted on Dec 17, 2008
jhinsincity
  • 616 Answers
SOURCE: tv will not stay on Proscan PS52690
power supply probably needs to be rebuilt, vertical IC some filters,probably a couple of transistors. best to have an experienced tech do it for you.
Posted on Aug 30, 2009
How do I fix a convergence problem on a Proscan 50
I dont know how to fix it, only had the tv for 3 months already having problems doesnt say much for proscan!!
Nov 08, 2012 | Proscan PS50700 50" Rear Projection...
Shrunken picture
HI!
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
Nov 02, 2007 | Proscan PS56670 56" Rear Projection...
I have a toshiba 65H82 tv i need to move to my new house. can i lay it down or does it have to be upright?
Move it upright best for the tv.These tvs have chemicals in it three CRT tubes colors guns.
Sep 08, 2010 | Toshiba 65H82 65" Rear Projection...
Tv buzzs when power is off.
Return the production without any further delay.
Oct 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Tv will not stay on Proscan PS52690
Aug 30, 2009 | Proscan PS52690 52" Rear Projection...
I HAVE A 80 INCH PROSCAN REAR PROG TV AND THE ON/OFF SWITCH WILL
it sounds like the main power supply. unfortunately spare parts are no longer available for this model
Feb 21, 2009 | Proscan PS52690 52" Rear Projection...
I have a proscan ps57660 rear projection tv, and the picture tube keeps jumping. its like the colors won't line up. every so often it will hold, but that is only when there is a full moon and martians...
TV repair guy is right. There are three separate tubes inside your tv (red, blue and green) that are set up to project perfectly on top of each other so that their pictures line up exactly. These tv's have shorter lives do to the fact that they are using the same technology as a conventional tv but they have seriously cranked the power up on these things. They run hotter and harder than any other tv out there. I recomend thinking fondly of the happy days that you had with this tv, then giving it a proper burial and upgrading to HD.
Jun 28, 2008 | Proscan Televison & Video
Jun 23, 2008 | Proscan PS60690 60" Rear Projection...
Is there a reset button for 52in rca hd ready rear projection tv?
Most likely there was one or more marginal connections on the main board and moving the set has completely opened those connections. If you can solder, try resoldering any connections on the boards that appear to be grainy or have rings. Update this with the results. That may resolve the problem. If not, we'll look further into the set for component failures.
Dan
May 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
Televison & Video Logo
32 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
