Distortion with Lexicon Alpha
I just purchased the Lexicon Alpha. After installing the software, all I get is distotion on playback. I have uninstalled the disc and downloaded the program from direct from thier site with no change in the problem.
  • ljgb Jan 07, 2009
    I have the same problem with the Lexicon Lambda. I'm running it on Vista on a HP computer. I can run it on my Compaq Vista but not the HP. I have downloaded Vista Codec 5.0.7 and still no luck. I would love some ideas please
  • connonm Mar 03, 2009
    I am having the same, seemling not just with Cubase 4 LE either. I tried it with reaper and tested the wav audio souces in media player and they were all clean.
Check that Cubase is actually using the Alpha ASIO driver in the VST part of the Setup menu under Devices.
I've just set up two of these and found that the ASIO driver was defaulted to the builtin cards driver.
I still don't get a nice clean signal though. It's definately not the best device in the world.
I wouldn't spend my own money on one!
Posted on Oct 19, 2010
Hi, I bought a Lexicon Alpha in order to use with Apple Mac (Logic). Now, my microphone is a dynamic microphone so it does not need any phantom power. When I connect the usb cable, the blue light comes...
I suspect the problem is with the software setup in your PC. Verify all the options and also verify that the AUDIO system is assigned as stereo and assigned to the Lexicon for both in and out... Also check any "PAN" control settings. There is a possibilty that the Alpha has a dead channel...
Try putting a stereo signal into the 1/4 inch jacks and see if both record... if NOT then take it for repair under warranty... I had a Lexicon Omega that had a problem myself... warranty repair...
Jan 10, 2011 | Lexicon Alpha Personal Recording Studio
My lexicon alpha is only a year old. line in 1-2 on the back has a distorted humming noise when any device is plugged in. What could be the problem and how could i fix the problem ? Thanks.
The probable cause is a ground loop. You haven't said what you are plugging in. These inputs are BALANCED lines and you MUST use TRS cables driven by TRS outputs of the thing you are driving it with. ALL interconnected equipment MUST be powered by the same receptacle or power source.
IF the thing you are driving it with does not have balanced outputs, then procure a DI (Direct Input) box and use an XLR cablle between the DI and the Alpha and set the DI on ground lift.
Dec 28, 2010 | Lexicon Alpha Personal Recording Studio
Lexicon alpha does not install with XP SP1a, error = "Cannot start device code (10)" Drivers from disk are installed, device is listed in device manager with a yellow exclamation point. Do i need...
You should be at SP2, but that MAY NOT be the problem. One thing to check is if you are supposed to have the device connected when you install the software... in SOME cases doing it with or without connection will affect the outcome. Also make sure ALL virus/spyware/popup blockers are disabled during install.
Before using this device, make sure that going to the control panel and looking at the "Sounds and Devices" shows that the Lexicon is the inout and output device for all the tabs within that window.
Dec 16, 2010 | Lexicon Alpha Personal Recording Studio
Have just purchased lexicon alpha to use on a Mac. Having trouble just getting started. Have hooked up a nice condenser mic into the alpha through the mic input on the rear and cannot get anything on the...
Make sure you have Phantom power turned on on the Lexicon... Oh,oh... it appears that the Alphs may NOT have phantom power which IS a REQUIREMENT for most condenser mics...
The Lexicon Omega does have this but apparently the Aplpha doesn't have it.
That leaves you with the choice of either getting a dynamic mic that doesn't need Phantom, or replacing the Alpha, OR using a preamp ahead of the mic before the Alpha...
Sorry, but those are the only solutions I see for you.
REMEMBER that condenser mics pick up everything and you cannot run them into a PA or they will feedback.
Oct 08, 2010 | Lexicon Alpha Personal Recording Studio
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
Apr 14, 2010 | Lexicon Alpha Personal Recording Studio
My DVD-rw drive can't install the DVD programs
Make sure the disk is for version 2.5 if you are using Vista. You can download it from the web.
Feb 15, 2010 | Lexicon Alpha Personal Recording Studio
My device manager doen't recognize the drivers i installed for my lexicon alpha
Here is the support site for downloads:http://www.lexiconpro.com/product.php?id=7#downloads Hope this helps.
Nov 26, 2009 | Lexicon Alpha Personal Recording Studio
No accompianing software with purchase of Lexicon Alpha Recording
http://www.lydrommet.no/artikkel/vis.php?id=37514try this click for the manual I have used it before for the same unit and the manual is here....Good luck Andy
Sep 15, 2009 | Lexicon Alpha Personal Recording Studio
Computers & Internet Logo
439 people viewed this question
David Payne
David Payne
