Question about Tefal Ultimate EZ Clean Pro Deep Fryer
Oil leaking out of deep fryer, and not into base ,but all around outside of fryer, this has happened twice. Very big mess to clean up
  • Anonymous Feb 15, 2009
    I have the same problem I returned it and pick up another one did the same thing messed up inside my cupboard. I still cant find were its coming from.
  • baileys419 Apr 18, 2009
    same exact problem, mad too!!!!
SOURCE: taking out the oil?
I am almost positive that you will have to lift the whole thing to empty the fryer. It looks as if it is one whole piece.
Posted on Jul 21, 2007
  • 52 Answers
SOURCE: Rival Deep Fryer -CF 153-WM
MarBeck.com - Small Appliance Replacement and Repair Parts 800-959-5656 M-F 8-5 CST Should have it. Good luck and pls review me if this helps
Posted on Jan 30, 2008
burzerko
  • 254 Answers
SOURCE: using peanut oil in GE deep fat fryer
Peanut oil contains oxcylic acid and could cause premature wear on your fryer.
Posted on Jul 01, 2008
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Posted on Aug 05, 2008
SOURCE: magnetic breakaway power cord for rival deep fryer
I have a Rival CF-250 cool touch deep fryer. Where do I get the magnetic breakaway power cord, filters, and filter cover.
Please let me know.
Thanks.
Ken Cooley
Posted on Oct 08, 2008
Oils leaks after cooking
Anne, defective, seam splitting or pin hole, discontinue use, if still under warranty return for exchange.
Mar 26, 2016 | Tefal T-fal Ultimate EZ Clean Pro...
Where could our frymaster MJ45 be leaking oil from
On that model the leak is usually around the fitting for the high limit or thermostat. These screw in the tank and sometimes need to be tightened a little.
Feb 10, 2015 | Frymaster Dean MJ45EMSD Deep Fryer
How do you empty the grease?
There's no really easy way. Let the oil cool. Place a piece of foil over one side of the rim and then use a ladle to remove as much of the oil as possible. Then remove the foil and quickly invert the fryer, not giving the last of the oil a chance to get around the edge of the rim. Wipe the rim with a paper towel before turning it right side up. Doing all this over a piece of newspaper help to control the mess.
Aug 28, 2014 | Sylvania Cool-touch Deep Fryer 1 Liter...
J goldstein deep fryer
Yes a spout is very handy to have. Not only does it cut down on the mess, it is a lot safer especially if the oil is still hot.
Oct 06, 2013 | Kitchen Appliances - Others
Oil leaking from the bottom of fryer
Do you let in from hot to cold that might do something to it. Need anew one
Feb 09, 2013 | Rival CF153-WM Deep Fryer
Flames coming up vent
Have you or someone converted this fryer to LP and/or back to Natural Gas? This sounds like your orfices are too big and the flames are shooting out, with leaking gas around the orifice itself? I would have the orfices redrilled, so you know they are correct, as this is dangerous... The only other reason you would have fire outside the designated area is because of a leak. When the pots leak, you will sometimes have the oil leaking catch on fire and burn around that leak area... You don't have a leak, do you? My best guess is the orfices are too big...and someone drilled them out that way...too big... Any further question or if you need new orfices, please call Paul or Susan at Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959. Thanks, Susan
Sep 10, 2011 | Pitco Frialator 40CNG Deep Fryer
My fryer is leaking oil from the tube inside I have a Master Dean fryers
If you are leaking oil by one of the burner tubes you can replace the tank or get a new fryer. new tanks usually cost around 400 plus installation. Usually better to replace the fryer.
Tom
Jul 23, 2010 | Frymaster Dean SR42G Deep Fryer
Leaking from oil holding pot
Using dyed water, locate leak(s), go to a welder that does stainless steel and get fixed. If leaks are detected where thermocouples pass thru tank, remove and re-seal fittings.
May 11, 2010 | American Range AF45LP Deep Fryer
Tefal Ultimate EZ Clean Pro Deep Fryer Logo
351 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
