Question about Garden
Poulan 1950 I have a low and high carb. adj. but they are restricted by a plastic covering over the adjustments. The plastic restrictors can be removed. I would like to set the carb. adjustments up like it is suppose to be coming out of the box. I cleaned the carb., replaced fuel lines and primer bulb and am having a hard time starting. I just got the saw so I don't have any history. I had it started a couple of times but ends up dying out and then difficult to start. I thought if I started with initial setting then adjust low 1/4 turn out until I get results then it would be downhill. What do you suggest? Joe joe_mich@rocketmail.com
  • 56 Answers
Tighten the left screw and right screw all the way.
losen the left screw 1 full turn and the right screw 1.5 turn and that should be the factory setting good day.
Posted on Jan 03, 2009
How do I adj carb when too lean
There are two screws on the carb (small ones) one adjusts the low and the other adjusts the high. very slight turns will get you what you need. Always remember where the screw started so you can get back if needed.
Oct 24, 2016 | Motorcycles
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
My Echo Blower Model 251 has given me problems ever since I bought it little over a year ago. It would not get full RPM's so returned it after reading the adjustments are set for 1100 ft. elevation and I...
there is one adjustment on the carb, but to get to it you need to drill or pick the black plastic cover out that is covering it, then you can adj the The blower at high speed and also check your exh screen to make sure thats not the prob before adj. carb. you will see jet just above top carb gasket at base of carb about ctr above wher it splits for diaphram good luck
Apr 12, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Nov 17, 2009 | Garden
How do I adjust carb on homelite b3850d chainsaw?
Should b 2 screws on side of carb. One is low speed adj and one is high speed adjust. Turn screws all the way in until they bottom, not too tight--turn them out 1 1/2 turns. Start saw and adjust the idle screw by turning in until it starts to sputter and turn out until is idles smooth same for hight speed only adjust at high speed
Aug 07, 2009 | Homelite Garden
My john deere 1600 weed trimmer starts fine cold, then runs on high speed for several minutes then dies .Then will not start.I cleaned spark plug, checked proper oil/fuel mix, cleaned air filter,tightened...
Your fuel low fuel high adj on carb arent set right. one is for idle and low running while other is for high rev. Getting these set just right is very tricky and takes some time doing it to become good,Im starting you off on a crash course,Im not gauranteeing anything but here it goes. LOcate the two fuel adj. screws on carb,if they have plastic caps on top remove them with needle nose pliers so the screws themselves are exposed. Next,I want you to take a screw driver and turn both in all the way till they stop. Now take and turn each one out counter clockwise three full revolutions. Now start it to see if theres any improvement. (Note: further adj. may be required you may have to consult an expert to have it be done for you if you cant get it).
Aug 02, 2009 | Garden
What is my lo hi carb adjustment for a Homelite Super XL ? with Homelite/Textron Div. Carb.
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Jul 01, 2009 | Homelite Garden
Carb adj on Ryobi blower 31cc
One adjuster is for the gas and the other is for air. (Honestly) To make the adjustment turn both to the right which should place them in as far as they will go. Next turn both adjusters out one and a fourth turn and begin your adjustment from there.
Jun 18, 2009 | Garden
Need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
Jan 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
522 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
