Question about Boss C550 Car Audio Amplifier
No power no sound
Im gettin power to the amp but the light is off. signal is good ground is good but still nothin???
    Problem Solver:
  • 9 Answers
This may be because there is no signal going to the RMT terminal on the amplifier. try connecting a +12v line, this line tells the amp to turn on. it is normaly connected to the header unit of the car so that it will turn on the amp when the unit is powered on.
Posted on Dec 28, 2008
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
Jun 05, 2010 | Car Audio & Video
I just installed a sony xplod 700 watt 4 channel amp and i was driving and my sound just went out, I could see that the deck was still playing and eq was still jumping but no sound, I checked the amp and...
loose connection to the power line and or ground. ground good be grounded poorly. best ground is to scratch the paint off the car frame under the carpet in the trunk and put a eyelet on the wire and screw it to the frame.also check your inline fuse on the power line from the battery if you dont have one you should. and also make sure you are using the right gauge wiring for your amp,
Mar 23, 2010 | Car Audio & Video
I have no brake lights or turn signals on my 95 gmc truck. I have replaced the boards but no luck. Also have checked fuses.
OK if the fuses are good , use a test light and check to be sure you have power at the fuse terminals. you'll check from ground to the terminal on top of the fuse. you should have 12vdc. then , check for power at your brake light switch on both terminals while the brake pedal is pressed, it is located located on the brake pedal assembly. also , check your hazard flasher switch to be sure it is not on. if it was on, check your flashers, both the turn signal and hazard flasher. If everything checks out , your problem is probably in your turn signal switch assembly located in your steering column.
Mar 14, 2010 | 1995 GMC Sierra
No sound from speakers, but there is power to amp
make sure the power wire and the remote wire have voltage. at least 12 volts. make sure the ground wire is good and has a good solid ground. after that make sure the rca cables are getting signal from the radio. if you have a small speaker or tweeter you can touch the wires from the speaker to the rca cables and it should play music very quietly. meter the subs and make sure theyre ok and not shorted or bad. if all that checks out good.... the amp is probably bad. start with all the simple stuff and work youre way up. if the amp has good power and signal and good speakers then the only thing thats left is the amp. good luck
Dec 29, 2009 | MTX X702 Car Amp
No sound
What brand of reciever are you using. Most pioneers have a floating signal ground and the shield of the input at the amp needs to be connected to chassi ground. Also if you had a previous amp failure and the power ground in your old amp opened the current to power the amp will flow through the signal ground of the reciever and burn the copper trace on the circuit board in the reciever. test this by connecting signal cable shield to car reciever chassi.
Aug 29, 2009 | Kenwood KAC-8401 Car Audio Amplifier
I install wire from the battery to the amp ground the amp then i installed the audio jack from the reciver to amp an then the speaker wire an nothin
Power amps must be connected + battery wire to the amp +b terminal with a gauge 8 or bigger depending on the power rating, - ground to the car chassis as short as possible,connect cords from head unit to power amp with good groundings, and remember to connect the speakers and the remote trigger from head unit to turn the amp on.
Aug 27, 2009 | Performance Teknique ICBM-772 Car Audio...
My Sony Xxplode Amp Not Working?
Most amp problem is due to bad connection. Specially check the main power. Sometimes it will indicate you are getting voltage but not enough current because of bed connection. For example it is possible for the on indicator light to be on, but you are not getting enough 'juice' to let it operate. Check the main fuse at the front by the battery.
Jul 05, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Boss C550 Car Audio Amplifier Logo
126 people viewed this question
Top Boss Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
