Question about Q-Logic QLT-.3508SS Car Subwoofer
Can it work with 220v?
Does anyone know if this subwoofer can be connected to 220v?
    Problem Solver:
  • 14 Answers
Car subs can NOT be connected to 220v. Not directly anyway. You will have to get an amp that can run on 220v & then connect it to this sub. Good luck finding a home audio amp that will run the sub though it's really hard. If you look at home theater setups you will find that all the subs have their own built in amps that are really hard to get a hold of seperately.
Posted on Dec 28, 2007
Makita Dc18rc from 110v to 220v
Did Someone Succeeded to Change the DC18RC from 110v to 220v ??
What are the component that should be replaced ??
Where can i get them ?
Thx ,
Lio
May 17, 2013 | Drills
My Cerwin vega xls 15s doesn`t work!
Blown circuit. The question is; was it the power supply that blew out or was it the amp? check for fuses and see if they are ok. If they are not, replace them. IF they are then you are going to have to get new amp and or power supply.
Apr 26, 2013 | Cerwin Vega Audio Players & Recorders
Woofer has popping noise
I have the same problem with my Cambridge Soundworks CSW250. Also one of the speakers doesn't work all the time. I'm sure it's a loose connection on the circuit board. When I tap the subwoofer near the connections, the popping noise changes (gets worse, better, other speaker works,etc.).I tried taking the subwoofer apart, but the area near the connections is sealed with glue, so I cannot access it. I hate it because when it works,it sounds so good. Anyone know how to get just the circuit board and back panel?
Aug 09, 2012 | Cambridge Soundworks Audio Players &...
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
My subwoofer IC got burned because i accidentally plug it to a 220v power supply, mine is only 110v i want to know the IC# subwoofer.
Most likely what got burnt is the bridge rectifier in the power supply section of the electronic circuit. This usually takes the shape of either a single 4-legged IC, or a group of 4 rectifying diodes connected in a bridge configuration. If you disassemble the unit to which the power cord is attached & trace the circuit starting from the terminals of the power chord, you can easily identify it. You will need to replace the 4-legged IC or the 4 rectifying diodes.
You will also need to replace the fuse, since it is usually likely that it gets burnt if the unit is attached to 220V instead of 110V.
Nov 24, 2009 | Altec Lansing FX4021 Computer Speakers
Sherwood RD7502
Hi - You can download the manual by clicking the link underlined in blue below:
RD-6108
Your sub woofer needs to have it's own power amp i.e. a "powered" sub woofer:
Assuming your sub woofer is powered & connect as shown then check the following setting:
Let us know how you get on.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 06, 2008 | Sherwood RD-6108 Receiver
Plugging in with multiple voltage requirements.
no... it will put out 220volts, same as the wll socket voltage. you will need a 220v to 110v stepdown transformer to run the sub.
Dec 15, 2007 | Onkyo HTR500 Receiver
Q-Logic QLT-.3508SS Car Subwoofer Logo
79 people viewed this question
Top Q-Logic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Q-Logic Car Audio and Video Expert? Answer questions, earn points and help others
